Really? no DIY for brake pad replacement?
Old 11-14-14, 04:20 PM
gsean400
gsean400's Avatar
Default Really? no DIY for brake pad replacement?
I'm trying to replace my rear brake pads on my lexus gs430, I have no idea where to start. I tried taking the bolt off the back and it seems like its really stuck on there. My rear left has 3% pad life left, can someone walk me through this? I need to use my car this weekend
Old 11-14-14, 04:33 PM
Chris147
Chris147's Avatar
it's actually quite simple.
I did it last winter without any guide or nothing.
But i'll link the Pdf for you, bro.
https://www.dropbox.com/s/u6xqq9s7v2...anual.pdf?dl=0
Just search Brake Pad or something similiar, I don't remember which page it's on.
Old 11-14-14, 04:46 PM
702GS
702GS's Avatar
Lets make one! I am about to convert to TT fronts, and do the rear pad and rotor replacement.
What do you say gsean400?
Old 11-14-14, 04:53 PM
burny
burny's Avatar
just pay attention to how the hardware is on the caliper holding the brake pads in there. Take a pic of it with your phone before you disassemble it
Old 11-14-14, 05:31 PM
gsean400
gsean400's Avatar
Lets do it, put your pictures of the replacement and ill switch the name of my thread title. And all the questions I ask will hopefully knock out some questions for others.
I was going to do that.
do I really need to use a torque wrench for the caliper bolt? This is my first time replacing breaks in a really long time.
I don't even remember how to bleed brakes
Old 11-14-14, 05:43 PM
lexo98
lexo98's Avatar
There are DIY's in the DIY section for brake pad replacement. From what I remember though it didn't show the correct lube points and I completely forgot where they are.
Old 11-14-14, 06:26 PM
gsean400
gsean400's Avatar
Wt eff is this..
Old 11-14-14, 06:29 PM
gsean400
gsean400's Avatar
I have never seen this, I unscrewed the bolt.. And it slides back, but not enough...
I'm so irritated.. Is the the one where u pull it out right there?
Old 11-14-14, 06:30 PM
gsean400
gsean400's Avatar
Yeah but None for a GS430
The site won't let me change my sig for some reason. I own 2001 gs430 now,
Old 11-14-14, 06:42 PM
702GS
702GS's Avatar
Pretty sure all gs use the same brake setup, no?
Old 11-14-14, 09:35 PM
NorthStyle
NorthStyle's Avatar
The GS300/400/430 all have the same brakes front/rear.
Old 11-14-14, 09:38 PM
gsean400
gsean400's Avatar
Thank you everyone for the support, it was simple after the first one, it was literally 3 pieces. The first piece in the way just popped off, then the W wire, then the pads just slipped out. No bolts were taken out. I think with my 20's i can remove the pads without taking the wheel off lol
Old 11-14-14, 09:41 PM
gsean400
gsean400's Avatar
Yeah I know, the DIY in the gs section was ls400s brakes and that's what threw me off.
Old 11-14-14, 11:46 PM
lexo98
lexo98's Avatar
I did the rears without taking the wheels off, but next time around everything is coming off to get cleaned, lubed and the rotors turned
Old 11-16-14, 03:11 PM
kit cat
kit cat's Avatar
Next time you tackle brake, I highly recommend you doing some research first before taking things apart. It's not the most complicated task to change pads, especially the rear opposing pistons, but brakes are not something you want to work on, screw up, and not function.
If you do decide to bleed the system on your own, please do more research. The master cylinder with its integrated ABS units requires some attention (opening each channel and order of bleeding each axle).
Stock S16 chassis calipers are between the front and back. Front is sliding and rear is opposed piston.
good luck.
Quick Reply: Really? no DIY for brake pad replacement?
