Replacing front suspension
Old 11-10-14, 12:42 PM
Lex2sea
Lex2sea's Avatar
Default Replacing front suspension
Hey lexus gurus.
So I'm replacing my entire front end suspension and before I get my hands dirty I wanna know if there's any little mishaps that may occur (I.e a special tool needed or something else lexus may throw at me as a set back.) I'm doing the control arms sway bars etc. also lowering it on coil overs some help would be greatly appreciated that's CL
Old 11-10-14, 01:38 PM
MotoEvo
MotoEvo's Avatar
A Pitman puller will help make the ball joints and control upper control arms easier to remove. A wire coat hanger will be nice to hold the brake caliper out of the way so you don't stress the brake line. Other than that, a good penetrating oil for the bolts.
Old 11-10-14, 06:17 PM
Lex2sea
Lex2sea's Avatar
Thanks brother another thing socket size? Maybe a 14?
Old 11-11-14, 06:35 AM
GSteg
GSteg's Avatar
You'll need 14mm, 17mm, and 19mm. A pitman puller would really help to get the lower balljoint out of the lower control arm.
Old 11-11-14, 07:27 AM
AKS14
AKS14's Avatar
Yep, basic hand tools and that ball joint puller (I got mine from Harbor Freight for like 19$ and it worked great)
If you are doing coilovers you may want to hole saw the body where the upper camber arm will hit and bang it up a bit and undercoat that area to buy you a little more room so you dont end up slapping the control arm to the body all the time before you put everything back together.
Other than that its pretty straight forward.
Old 11-11-14, 09:31 AM
Lex2sea
Lex2sea's Avatar
Thanks again y'all ! Much appreciated
Old 11-12-14, 06:39 PM
702GS
702GS's Avatar
Just did this exact job on my GS, you do NOT need a pitman puller! Use a hammer, its way easier.
ancdmd
04-11-16 03:25 PM
static88
Suspension and Brakes
03-25-14 08:46 AM
motorscape
08-16-12 06:08 PM
rob22
07-17-09 07:39 AM
Quick Reply: Replacing front suspension
