Wide Wheels?
Old 11-04-14, 02:00 AM
azureglade
azureglade's Avatar
Default Wide Wheels?
Just bought my first IS yesterday "Living Australia btw too", looking around for new wheels at the moment. Ill probably get either Work VS-XX's or a nice set of SSR's.
But the only issue I'm having is offset, I also own a Supra and am very used to being able to fit almost any size wheel on it have 19 x 10.5's on the Supra at the moment.
Can anyone help me with a comfortable rim size that will work with the IS?
Old 11-04-14, 12:17 PM
Gville350
Gville350's Avatar
You can fit the same size wheel on the 2IS; might take a little work, but it will fit. Hell, there are those rocking 12s in the rear!
Old 11-05-14, 01:37 AM
azureglade
azureglade's Avatar
Ah ok, I have seen some with pretty wide ones at the back but wasn't sure if they had done any work on the guards or not.
Thats good then I have 10.5's all round on the Supra at the moment and was about to upgrade to 12's.
Old 11-05-14, 07:27 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Here are some examples. Most basic setups for an AWD range from an 8.5"-9.5" up front (the wider needs more work). 9.5"-10.5" in rear.
https://www.clublexus.com/forums/is-...rs-thread.html
Old 11-06-14, 04:06 AM
azureglade
azureglade's Avatar
Right, but what about offset?
Old 11-06-14, 06:35 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Depends if you want to roll or pull your fenders/quarter panels. Without any work usually +35- +45 offset.
Old 11-06-14, 12:08 PM
azureglade
azureglade's Avatar
Ah ok no worries. Thanks, I'm terrible with figuring out offset etc haha.
Old 11-06-14, 01:44 PM
Need4Speed
Former Sponsor
Need4Speed's Avatar
Here are some set ups we get on a regular for IS:
19x8.5+35---235/35/19
19x9.5+45----275/3019
or
20x9+32---225/30/20
20x10.5+45---255/30/20
With no rubbing issues
Old 11-10-14, 12:18 AM
albertgoq
albertgoq's Avatar
hi folks
would this work no fender or camber mods?
18x8.5 +37 235/40/18
18x9.5 +38 255/35/18
Old 11-17-14, 09:38 AM
Smashin
Smashin's Avatar
I am running 18x9 +38 255/40r18 front and 18x10 +38 285/40R18 rear ... No modifications but I have slight rubbage when turning in the front also on 1.25" drop with 14k/12k spring rates on full stiff for dampening adjustments...
Old 11-19-14, 09:18 AM
rigid9
Registered User
rigid9's Avatar
Could you post or PM a picture of that setup? I am interested in a very similar configuration, specifically running 18x9 - 255 up front. Where is it rubbing?
Thanks!
Old 11-24-14, 04:30 AM
BennIS250
BennIS250's Avatar
Hey mate I live in Australia too and just got my SSR Koenigs today! The specs are 18x9+4 in the front and 18x10+4 in the back, i test fitted them without camber and coilovers and they poke a lot but once the camber is on i reckon everything will tuck nicely, heres a photo of the front.
*EDIT* Also will be having my guards rolled but not a big hassle!
Old 12-02-14, 02:50 AM
azureglade
azureglade's Avatar
I've also been looking lately at Work Rezax, theres a set for sale atm I'm considering. Sizes are 18x9 +9 18x10 +7.
Anyone know what this will be like on the IS? Will many adjustments be needed etc?
Old 12-08-14, 12:51 AM
BennIS250
BennIS250's Avatar
Well if you look at my set up, the dimensions are the same and the offset is slightly different, so theyll be similar fitment to mine!
Old 12-08-14, 01:39 AM
ISland350
ISland350's Avatar
running 10.5 +15 in the rear...needed fender roll and pretty big pull
Quick Reply: Wide Wheels?
