Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation > Suspension and Brakes
Sign in using an external account
Register Forgot Password?
coilover top mount nut loose, happened to anyone?
Thread Tools Search this Thread Display Modes
Old 10-10-14, 09:59 PM   #1
monkey92
Trader Score: (0)
monkey92's Avatar
Default coilover top mount nut loose, happened to anyone?
hey guys how many on here have experienced the nut on the top mount of a coilover come loose? my car started bouncing in the rear while i corner sometimes and today i noticed it was leaning more towards one side. took the trunk liner off and found one the nut was completely loose. has this happened to anyone before? i feel like this has changed my preload and possibly there isnt any tension on the spring at the moment. didnt have time to take off the tire to check it out today. but was wondering if this has happen to someone else before and if its a common occurrence.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
monkey92 is offline   Reply With Quote
Old 10-11-14, 07:33 AM   #2
NYKnick101
Trader Score: (0)
If it wasnt tightened down properly, then it could have vibrated loose during your daily drives
NYKnick101 is offline   Reply With Quote
Old 10-11-14, 03:45 PM   #3
monkey92
Trader Score: (0)
monkey92's Avatar
ive never touched it since installing them out of the box. now when i slightly tighten it, the whole shaft spins so i cant really tighten it too much. would you happen to know if that is normal? maybe its time for a rebuilt?
Old 10-12-14, 04:46 AM   #4
brainsurge
Trader Score: (0)
brainsurge's Avatar
Normally there is a way to fix these in place while applying torque. Either pliers or allen key and then torque it with a ring ratchet. impact wrench might also work, but be careful with that. when did you install them and how old are your coilovers? normally that would not come loose.
brainsurge is offline   Reply With Quote
Old 10-12-14, 09:58 AM   #5
monkey92
Trader Score: (0)
monkey92's Avatar
they are about 2 year old coilovers. i will try to check again today and see if i can apply some torque to tighten it.
Old 10-12-14, 12:15 PM   #6
NYKnick101
Trader Score: (0)
yeah most suspensions there is an allen key on the shaft and you have to tighten with a wrench or something. Never spin the center shaft because it is a screw down in the shock body
Old 10-12-14, 12:31 PM   #7
monkey92
Trader Score: (0)
monkey92's Avatar
what happens when the center shaft is spun a little? i might have spun it maybe a turn yesterday when trying to tighten it down.
Old 10-12-14, 01:04 PM   #8
brainsurge
Trader Score: (0)
brainsurge's Avatar
Its nothing to be concerned about, nothing is going to happen. just make sure you get it torqued.
Old 10-12-14, 04:37 PM   #9
monkey92
Trader Score: (0)
monkey92's Avatar
cool awesome, ill get in there and torque it down and see why it changed height since the car is leaning on that side.
Old 10-16-14, 11:11 AM   #10
maxx430
Trader Score: (0)
I have the same problem. My rear driver side bolts came loose. I noticed it because I can hear a noise coming from that area. I removed the wheel and was able to lift the entire hub assembly up slightly, which caused the squeaking noise from the top. As i move the hub assemble up slightly, the shock would compress. I tighten the bolt with the car off the ground but the noise is still there. I think i need to lower the car to apply the weight back on the car and then tighten. Not sure how it got loose though. what are you torquing the bolts too?
__________________
maxx430 is offline   Reply With Quote
Old 10-16-14, 07:14 PM   #11
monkey92
Trader Score: (0)
monkey92's Avatar
i havent torqued them down yet, i switched over to oem for the winter last night and was too late at night to mess with them, when i took that particular coil out i found that the bottom perch was completely loose too. im going to find some time and take a look at them.
Old 10-17-14, 06:39 PM   #12
maxx430
Trader Score: (0)
i just noticed mine was uneven on both side. my left side is lowered more than the right, but the car sits evenly that way. have you had this issue?
__________________
Old 10-17-14, 07:51 PM   #13
monkey92
Trader Score: (0)
monkey92's Avatar
i dont have that issue. mine was one coil was lower than the other cause the car to be uneven.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Megan Racing EZ Street Coilovers Bang Noise? mrrhr4 Suspension and Brakes 7 09-02-13 10:37 PM
Lug nuts loose!!! 1JZPWRD SC 400/300 15 04-25-13 07:14 AM
F Sport Lug Nut Manufacture? Hoac IS - Second Generation 5 04-07-13 06:25 PM
P0420 code, cat problem....no! boxbrownie RX - First Generation 2 04-05-12 12:27 AM
A 20+ year mishandling with wheel nuts chenxingha RX - First Generation 1 10-31-10 03:06 PM
Join ClubLexus
Advertising
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
