Is350 Shock life expectancy
Old 09-30-14, 04:32 PM
Gerb
Gerb's Avatar
Default Is350 Shock life expectancy
Anyone know how long they last? Im at 111k km atm. Just added H&r springs at 109k.
Old 09-30-14, 10:55 PM
Boomin
Boomin's Avatar
I guess 160k km
Old 10-02-14, 10:28 PM
Gerb
Gerb's Avatar
Probably, I don't see it in my maintenance record from previous owner
Old 10-06-14, 10:04 AM
UniSlayEX
UniSlayEX's Avatar
SA says 100k mi but they can go out sooner dependent on driving style. I personally feel 75k mi is a good time to start looking at changing them.
Old 10-11-14, 08:49 PM
Chakerus
Chakerus's Avatar
Mine blew at 95k miles. Probably started to leak earlier.
Old 10-12-14, 07:39 AM
Sceanzo
Sceanzo's Avatar
My shop doesn't replace them until they are leaking or making noise. Unless you want to do preventative maintenance.
Old 10-12-14, 12:06 PM
NYKnick101
NYKnick101's Avatar
Most shocks usually are rated for 80k but depending on driving style and location, they can last alot longer, or alot shorter. I have had shocks last 150k miles plus on oem, and then again i had others that blew after 15k.
Old 10-29-14, 01:37 PM
FSportIS
FSportIS's Avatar
My IS350 shocks last 90k miles and still works fine with no leaking. I changed them to F Sport springs/shocks anyways as preventive maintenance.
My IS250 sport shocks are at 35k miles on Eibach lower springs. I drive it hard everyday and the suspension is still working like 1st day. I expect it to go to 60k miles on this one and then I will go coilovers
Are shocks carrying the 50k miles/5 years warranty from Lexus??
Old 10-30-14, 08:55 AM
Sportskid1
Sportskid1's Avatar
My front shocks started to leak at 25K. But then I am pretty hard on my car. You just never know.
Old 10-30-14, 09:13 AM
FSportIS
FSportIS's Avatar
Sportkid, you are an exception lol--track junkie you do like what 10 track events in a year. What set up do you run right now for track?
Old 10-30-14, 03:56 PM
Sportskid1
Sportskid1's Avatar
Yah but the OEM shocks were leaking after my 5th track day! The crappy So Cal roads don't help either though. But all in all I don't baby my IS and she takes it like a champ.
Currently running BC coilovers with swift 12/10K spring rates. Really like them. Great on the street with the dampening turned down and huge improvement on the track when set up correctly.
Old 10-30-14, 04:07 PM
FSportIS
FSportIS's Avatar
I'm thinking about going BC coils for my IS250 using 10k/8k spring rates (no Swift upgrade). How does the ride quality compared to stock? If not, would the softest settings on dampening make it stock like assuming only lower around 1inch or so with plenty suspension travel. I mainly run my IS250 as daily driver with occasional autocross.
How many clicks do you use (1 being softest and 32 being hardest) for daily and on track?
Old 11-01-14, 08:57 AM
Sportskid1
Sportskid1's Avatar
I really like the higher spring rates and think the ride is great. It is a bit firmer than stock but not bouncy or jarring at all. You notice it for sure if you hit a big pothole or speed bump but for everyday driving I would never go back to the OEM spring rates. But I do prefer a firmer ride so I might be a bit biased. I am running at 16 clicks on the front and 12 on the rear for everyday driving. For tack I generally stiffen it up about 10 clicks on each end. All in all very happy with the setup
Buya02
Suspension and Brakes
03-12-14 12:04 PM
lexusben
11-21-12 04:27 PM
autovation
14
11-06-08 11:50 AM
jracerlmn
08-31-05 05:48 PM
Dsmart
03-23-05 09:49 AM
Quick Reply: Is350 Shock life expectancy
