Airstrut bags installed
Old 07-30-14, 06:20 PM
weeters
weeters's Avatar
Default Airstrut bags installed
Just installed airstrut bags. It is easy to install but you can forget about the trunk.
Attached Thumbnails Airstrut bags installed-img_20140730_171104.jpg   Airstrut bags installed-img_20140730_171038.jpg
Old 07-30-14, 06:22 PM
Albatross
Albatross's Avatar
pics of trunk. NOW. please.
Old 07-30-14, 06:33 PM
weeters
weeters's Avatar
didn't take any cause its a mess but i'll post it tommorow when i get to the shop
Old 07-30-14, 07:13 PM
CatManD3W
CatManD3W's Avatar
Post up some pics of the air struts....
Old 07-30-14, 07:22 PM
weeters
weeters's Avatar
i'll post a couple of pics tommorow maybe a little diy notes. the kit i bought uses the stock struts with you simply cutting the spring perch off. i used the factory mounts modified slightly.
Old 07-31-14, 06:21 PM
weeters
weeters's Avatar
heres a pic of the strut. very bottom of spring perch cut off.
Attached Thumbnails Airstrut bags installed-img_20140731_174630.jpg   Airstrut bags installed-img_20140731_172845.jpg
Old 07-31-14, 08:01 PM
jennie
jennie's Avatar
You're using the stock struts?! You better have some replacement struts ready..
Old 07-31-14, 11:22 PM
Blkexcoupe
Blkexcoupe's Avatar
What size air lines are you using? Is it front and rear lift only or independent 4 corners?
Old 08-01-14, 11:51 AM
weeters
weeters's Avatar
3/8" front back and pancake.
Old 08-01-14, 04:19 PM
weeters
weeters's Avatar
this is all the way down
Old 08-01-14, 09:37 PM
babowc
babowc's Avatar
If you don't mind, what'd the setup run you and where did you get it?
Old 08-02-14, 02:31 AM
weeters
weeters's Avatar
uas suspension. nobody around here did it so i became a dealer.
Old 11-09-14, 09:02 AM
eblick99
eblick99's Avatar
ive been looking at coilivers but i want the ability to hit a button and raise/lower my car. ive got 19's and a body kit so driveways/speed bumps are my #1 enemy. how much would you guess the whole system weighs? ive seen some mechanically adjustable suspensions, that use a servo and screw mechanism to adjust ride height i wonder how those compare in ride comfort, price and weight to an air ride. is an air ride setup doable on a budget of $2000?
Old 11-10-14, 08:05 AM
weeters
weeters's Avatar
2000 is more than enough. I do the kits install at 1800. I'm running two switches front and back. i can do pancake as well. This pic is how the car sits with the acs kit and 19s.
Old 11-10-14, 08:10 AM
weeters
weeters's Avatar
side view before skirts
Quick Reply: Airstrut bags installed
