MOOG outer tie rod the same on both side?
I ordered outer tie rod from rockauto and received both side, each with different part number. However they both said R on them and the shaft bends the same different. I then ordered one from amazon, and it still has R on it and bends the same way as the passenger side does. Is the left and right side the same tie rod?
hard to believe rockauto and amazon both sent me tie rod that are meant for the right side.
I am returning to amazon. I bit the bullet and sent to Autozone to pick up the driver side tie rod, no longer can wait. Apparently, their tie rod are made in Japan by 555. however they do not carry the one with zerk fitting for greasing. It sure does not look beefy as the one from Moog Problem Solver.
Hey guys,
New GS300 Owner. I actually also just bought a ton of stuff from rockauto and received the same issue. I filed a report about the issue and even sent them photos of the two rods showing R and the boxes being marked as different. Will keep everyone posted with the outcome.
I don't know what's going on here. I have ordered products from RockAuto a few times before. I have never had any problems. Most recently ordered tie rod ends and lower ball joints for my GS300. This is what I got.
My problem ! Right references, but wrong parts, the left tie rod end is not "probleme solver" but a 555
Can someone help me to explain my probleme to rockauto ? Because i don't speak englih very well and sometimes i don't understand all the sentences. Thanks
I understand your problem. I emailed Rockauto and they refunded my money and told me to keep the product. In the end, i used the same thing you have, they are mismatched. I was not able to wait for another order.
hey Everyone,
Just as an update.Rock Auto Never replied back to me. I ended up getting the ends somewhere else. I probably should of called but its been hectic for me to even do that. cant wait on hold all the time. oh well they were really cheap and ive been able to get a ton of other parts from them as well.
hope everyone gets this all figured out soon. if i get any time to contact them ill keep the group posted. thanks for all the help everyone.
Hi, have the same problem like RKTV.
For RKTV,
i have the same problem with this parts but i recieved opposite sides. Do you want make change?
I am from Czech Republic so the post costs will be not expensive.
Write mi a PM to change adres.
Michal
Read more: https://www.clublexus.com/forums/sus...ont-end-3.html
Michal
