What Size Spacers 2 Use For 22's?
Old 06-30-14, 01:54 PM
SupraFlyGS
SupraFlyGS's Avatar
Default What Size Spacers 2 Use For 22's?
Anyone have 22's on their 2nd gen with spacers? If so what measurements worked for you spacer wise?...
Thanks in advance!
Old 06-30-14, 06:52 PM
NorthStyle
NorthStyle's Avatar
Hmmm... well, without knowing anything about the wheels (width/offset) or the tires, we can't do anything for you when it comes to offering advice.
You may want to look into the Wheel Size & Offset thread or better yet the Dub Style sub-forum as most people here don't run anything larger than 20s.
Old 07-03-14, 12:56 AM
SupraFlyGS
SupraFlyGS's Avatar
Thanks...mines came with 20's but sold them...had 22's sittin' for a 745 or 750 Li...haven't got the bimmer yet...so gonna put these on...245/35/22 9.5
I'll check out the suggested sub-forums...thanks....
Old 07-03-14, 01:27 PM
offbad
offbad's Avatar
are you going to use 5x114.3 adapters?
Old 07-04-14, 07:34 AM
SupraFlyGS
SupraFlyGS's Avatar
Yeah...should I go with another pattern? I thought that the spacers alone would do but studs weren't long enough...I see some places online you can order the spacers/adapters with pre-installed studs?...Just lookin' for a place that has the pre-installed studs and want to be sure I'm getting the correct adapters/spacers for the 22's...
Thanks...
Old 07-04-14, 10:37 AM
LexRuger
LexRuger's Avatar
The 745 has a 5x120 bolt pattern and the Lexus has a 114.3 bolt pattern you're going to need adapters. Adapters will push the wheels out. But I'm 90% sure the wheels will stick out too far because the 745 has a low offset and the GS has a mid to high offset.
If you tried to make it work, you'd need smaller tires. Like a 235/30/22
Old 07-13-14, 01:28 AM
SupraFlyGS
SupraFlyGS's Avatar
Thanks LexRuger...you know ur stuff...I took my lex to the rim shop...guy said to use 225/30/22...like u said the adapters pushed them out too far and funny you mentioned the 745...that was the car these rims were sitting for but haven't made my way to purchse it yet.
buckwhite
04-13-12 05:35 AM
kingbigs11
03-08-10 07:24 PM
tsavo
05-04-09 11:46 AM
corkycal
Wheels, Tires & Brakes Forum
08-05-04 12:59 PM
jdmdaddy
09-15-03 06:10 AM
Quick Reply: What Size Spacers 2 Use For 22's?
