Question about custom/modded front UCA
Old 06-26-14, 09:14 PM
LexusGuyyy
LexusGuyyy's Avatar
Default Question about custom/modded front UCA
For the guys who are running custom or modified front UCA what exactly are you guys doing? Cutting the actual arm shorter? I was told it was to help achieve more camber in the front to run a wider wheel. I'm just preparing myself before i end up not having enough negative camber to achieve the 10.5 -3 offset for my fronts.
Old 06-27-14, 08:46 AM
Sportskid1
Sportskid1's Avatar
I am running the Megan UCA in mine. I am not lowered a bunch (about a finger gap) and installed them so I could get the camber needed for my track time. Maxed out I was about -3 deg in camber. Currently running -2. For my setup I could adjust it from about 0 to -3 degrees. If you are lower you will obviously be able to get a bit more camber depending on how low you go. All in all I am very happy with them. Easy swap.
WylieKylie
WylieKylie's Avatar
No need to build your own arms. There are three mainstream solutions to get more negative camber up front. Megan Racing upper control arms, SPC adjustable ball joints, or FIGS offset bushings.
Of the three solutions I like Megan Racing arms, so that is what I have:
I believe they give you a little more adjustment range vs SPC joints, and they don't require the UCA to be removed to adjust camber like the FIGS bushings. You won't get -3 degrees from any of these solutions at stock ride height. Lower the car ~2 inches in front and I think any of them will give you the -3 degrees you are looking for.
10.5" wheels are way wider than what I would consider, so I'll let someone else adress the rest of the mods to make that work.
Old 06-27-14, 12:41 PM
Gville350
Gville350's Avatar
Don't forget about these as well!
http://shopfigs.com/v1/index.php?rou...product_id=197
Old 06-27-14, 06:53 PM
laobo979
laobo979's Avatar
Figs is also in the process of making an whole upper control arm. They're can go as far as -4.5 or more I believe.
Old 06-28-14, 12:38 PM
LexusGuyyy
LexusGuyyy's Avatar
Thanks for very informative information, I was looking into the SPC ball joint since i've already acquired the megans uca, also laobo979 any ETA on those arms?
Old 06-29-14, 08:33 AM
rawr2is250
rawr2is250's Avatar
Wow -4.5 in the front, haven't seen much of people running something like that on these forums much.
Old 06-30-14, 10:24 AM
WylieKylie
WylieKylie's Avatar
FIGS UCA would be nice, but -4.5 degrees at what ride height?
Old 07-01-14, 07:16 PM
laobo979
laobo979's Avatar
I don't know what height was but it was on they're ISF. Contact them for the info but you can see the pic on Instagram.
Old 08-03-14, 12:13 PM
JETLEX
JETLEX's Avatar
Just wanted to reiterate for some of those looking that it depends how low you are to begin with, and how much clearance you have at the spring perch, etc.
*Not directing this to you laobo979, only putting your quote in there so people will know what I am referring to.
Old 09-02-14, 01:15 AM
BoyOhBoy
BoyOhBoy's Avatar
Also want to know if there's a method on getting more front camber
Old 09-02-14, 07:19 PM
EZwider
EZwider's Avatar
I am currently running -4.5 degrees of front camber with the Megan UCA.
Looking to go more negative, with a new wheel setup. so I am going to cut out one row of allen screws to shorted the platform the ball joint is on.
Will be posting pics on my build thread.
I really want to get the T-demand front UCA and shorter knuckles to stop the arm from hitting the top of the wheel well, but those are bread. So well see what happens.
fryer
Suspension and Brakes
09-28-16 12:35 AM
Vumanchoo
10-02-13 10:22 AM
ozzy250
04-19-13 12:42 PM
tp350
13
07-27-12 11:05 AM
ISRabbit
02-09-12 07:51 PM
Quick Reply: Question about custom/modded front UCA
