Can you adjust preload when coilovers are on car?
Old 06-03-14, 05:40 AM
srob817
srob817's Avatar
Default Can you adjust preload when coilovers are on car?
This may be a dumb question, but I installed my BC coilovers this past weekend and I did not check the preload. I am not getting any noise from them but i just want to make sure that the preload is set correctly. I know how to set the preload but all the videos show it off the car. Can I do it with them installed?? Like maybe remove the mounting bolts up top to release the strut, then make the adjustment???
Old 06-03-14, 09:18 AM
whiteraven
whiteraven's Avatar
unbolt the coil from the bottom, then you can freely adjust the preload.
Old 06-04-14, 04:18 PM
Spyder78
Spyder78's Avatar
Preload is adjusted by the perches that are under your springs. You do not need to unbolt anything except maybe the wheel. Jack each side up and tighten the perches under your springs.
Old 07-17-14, 12:33 PM
GSGenesis
GSGenesis's Avatar
Yup what he said^ nothing needs to be removed bro. Adjust away. I tightened mine a bit just as it sits
trbosmitty
Suspension
13
03-03-17 03:36 PM
Tro209
12-10-15 09:55 AM
Bradwillia
Suspension and Brakes
12-12-13 12:17 PM
woodpecker
12
04-11-10 11:59 AM
Lexi D
20
09-16-09 12:17 PM
Quick Reply: Can you adjust preload when coilovers are on car?
