Can you adjust preload when coilovers are on car? - Club Lexus Forums
Thread Tools Search this Thread
Old 06-03-14, 06:40 AM   #1
srob817
srob817's Avatar
Default Can you adjust preload when coilovers are on car?
This may be a dumb question, but I installed my BC coilovers this past weekend and I did not check the preload. I am not getting any noise from them but i just want to make sure that the preload is set correctly. I know how to set the preload but all the videos show it off the car. Can I do it with them installed?? Like maybe remove the mounting bolts up top to release the strut, then make the adjustment???
srob817 is offline   Reply With Quote
Old 06-03-14, 10:18 AM   #2
whiteraven
unbolt the coil from the bottom, then you can freely adjust the preload.
whiteraven is offline   Reply With Quote
Old 06-04-14, 05:18 PM   #3
Spyder78
Spyder78's Avatar
Preload is adjusted by the perches that are under your springs. You do not need to unbolt anything except maybe the wheel. Jack each side up and tighten the perches under your springs.
Spyder78 is offline   Reply With Quote
Old 07-17-14, 01:33 PM   #4
GSGenesis
Yup what he said^ nothing needs to be removed bro. Adjust away. I tightened mine a bit just as it sits
GSGenesis is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
BC Coilover Preload Setting MamadIS Suspension and Brakes 11 10-01-15 06:11 PM
Stance gr+ preload setting Sleepy2is Suspension and Brakes 4 10-12-14 08:43 AM
Adjusting preload on new bc coilovers? BoyOhBoy IS - 2nd Gen (2006-2013) 14 09-09-14 01:34 PM
Adjustable Sway Bar End Links TechGreek Suspension and Brakes 66 07-09-14 04:59 PM
Adjustable end link experience with aftermarket sway bar darbs242 IS F (2008-2014) 3 07-26-13 11:35 AM
Tags
adjust, bc, car, coilover, coilovers, preload, release, setting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
