figs swaybar end links
Old 05-06-14, 11:20 PM
Tank
Tank's Avatar
Default figs swaybar end links
Hello all,
Ran into a little snag installing the figs endlinks. After torquing down the bolt that holds the endlink to the LCA I noticed there was a small gap between the threaded endlink cap and the LCA. I made sure I torqued to specs but there was still that small gap. I removed the bolt to see if the end of the bolt was making contact with the end of the threaded cap and sure enough the threads had been crushed a little. I decided to install some 1/2 inch washers and everything is nice and snug. Might not be an issue with all the endlink kits but for mine the bolt was a little bit too long. No big deal. Just an FYI or I could be installing it incorrectly..lol
Click image for larger version
Old 05-07-14, 07:13 AM
RXGS
RXGS's Avatar
How easy are these to replace? Mine have a ton of play in them and I was just going to replace them with the moogs
Old 05-07-14, 07:38 AM
SorrGwa
SorrGwa's Avatar
noticed the same, and did the same thing with the washer. otherwise, it just gets noisy,
Old 05-07-14, 05:21 PM
Tank
Tank's Avatar
Remove three fasteners and your done. but the figs are adjustable.
Old 05-07-14, 05:22 PM
Tank
Tank's Avatar
Question if you don't mind how do you have yours adjusted?
Old 09-07-17, 07:45 PM
Yodog
Yodog's Avatar
Sorry to revive but I would like to know how you guys adjusted your front and rear figs sway bar endlinks.
i noticed where the two bearings meet, they are not aligned correctly, they look crooked. Is there an easy way to fix this? How to fix? And how to adjust to ideal settings?
Old 09-09-17, 07:57 PM
Tank
Tank's Avatar
can you take a pic and post it here?
Old 02-27-18, 09:31 AM
captainva
captainva's Avatar
Can someone tell me what the advantage of the Figs endlinks is over OEM and what the advantage of the adjustability is? I've been searching but there's no clear answer
Old 02-27-18, 08:26 PM
k7q
k7q's Avatar
I remember reading something that sway bar should be horizontal when the car is in the floor. That's where adjustable end links are good for lowered cars.
Old 02-28-18, 07:15 AM
captainva
captainva's Avatar
Thanks for the explanation!
Old 04-12-18, 08:12 PM
Tank
Tank's Avatar
Your welcome.
WIL44
07-06-21 03:00 PM
madchyers
IS - 1st Gen (2001-2005)
39
08-19-19 04:52 AM
meade916
IS F (2008-2014)
50
07-29-15 04:39 PM
Weapon F
04-25-11 08:00 PM
Quick Reply: figs swaybar end links
