Coilover
Old 04-24-14, 07:14 PM
landpham1
landpham1's Avatar
Default Coilover
Is it a good idea to get coil over for the is 350 f sport 2014 or leave it factory?
Old 04-24-14, 08:30 PM
TheShaddix
TheShaddix's Avatar
If you want a mild drop, get springs. But If you're looking to play with the ride height and other things to set it up perfectly the way you want, then you should get coilovers. Also, coilovers will generally ride better than just springs with stock shocks. Plus you'll be able to set custom dampening depending on the occasion. The factory system doesn't compare at all. The only cons of coilovers are the price, cost to install (unless you do it yourself which I did but it's a total pita), and you'll have to adjust it a few times before you finally get it perfect as far as ride height.
Old 04-24-14, 08:43 PM
landpham1
landpham1's Avatar
thanks for suggestion. Any suggestion on coil over?
Old 04-25-14, 10:29 AM
TheShaddix
TheShaddix's Avatar
At this point i'm inclined to say J5 is your best bet. Not a huge fan of my RS-R sports anymore as they are way too damn soft (the springs). Not sure how J5 is but they probably have more spring rate options to choose from unlike rs-r.
Old 05-26-14, 12:09 PM
landpham1
landpham1's Avatar
Default rims
Would it possible if i want a 20" wheels with the front 20 by 9 and the rear 20 by 10.5?
Old 05-26-14, 03:18 PM
Mr_VFS1
Mr_VFS1's Avatar
Depends on if you're willing to do any fender modifications.
hube
Suspension
13
05-28-16 04:30 PM
Chiubacca
02-16-16 03:31 PM
Och
Suspension and Brakes
05-17-10 01:57 PM
kindred6ul
51
04-24-07 12:54 PM
jewel
07-20-06 12:11 PM
Quick Reply: Coilover
