Goin' Figs / Skip the Daizens.
Old 04-22-14, 11:57 PM
Tank
Tank's Avatar
Default Superpro vs. OEM/Daizens
Decided to upgrade bushings (etc.) in front now that Figs has finally made available the #1 lower control arm bushing. The final piece of the puzzle. Also decided to switch out the aftermarket bushings I installed on the caster arms which "egg out" under load.
As I continue to install the new equipment I will follow this thread up with new pics. stay tuned
P.S. Sorry for the crude methods and offset pics.. I have to improvise sometimes and use whats at hand. And my phone keeps rotating the pics for some reason..
Attached Thumbnails Goin' Figs / Skip the Daizens.-20140421_155312.jpg   Goin' Figs / Skip the Daizens.-20140417_180854.jpg   Goin' Figs / Skip the Daizens.-20140417_180937.jpg   Goin' Figs / Skip the Daizens.-20140417_180904.jpg
Old 04-24-14, 11:13 AM
Tank
Tank's Avatar
Default OEM bushing
#1 LCA. According to the install instructions the lip on on side of the OEM bushing needs to be bent over with a chisel to allow the bushing to be pressed out from the other side.
I found this a little difficult to do. I guess my shop press wasn't strong enough (12 tons) and I had to improvise with what I had to use to press out the bushing so I chiseled the whole thing over.
Attached Thumbnails Goin' Figs / Skip the Daizens.-20140417_190718.jpg   Goin' Figs / Skip the Daizens.-20140417_190708.jpg   Goin' Figs / Skip the Daizens.-20140420_170848.jpg
Old 04-24-14, 11:19 AM
Tank
Tank's Avatar
Default 32mm socket used to press out bushing
Before I bent the lip over with a chisel to make it look like a "crumpled star" I pressed out the rubber coated middle shaft part of the bushing. I felt it would be easier to press the bushing out if I removed this part first. I then used a 32mm deep socket to press out the bushing from the lip side.
Attached Thumbnails Goin' Figs / Skip the Daizens.-20140420_171254-1-.jpg   Goin' Figs / Skip the Daizens.-20140420_170931-1-.jpg   Goin' Figs / Skip the Daizens.-20140420_170937.jpg
Old 04-25-14, 08:39 AM
FIGS
The Maker
FIGS's Avatar
Thanks for the write up. As always if there is anything you encounter during the install that we can improve let us know.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 04-25-14, 08:27 PM
Tank
Tank's Avatar
Default ...................
Mike
So far so good sir thank you.
should be posting up some more install pics this weekend. Literally waiting for some paint to dry.
I will take you up on that offer if I run into any road blocks.
Thanks.
Old 04-29-14, 08:01 AM
Tank
Tank's Avatar
Default LCA Bushing install..
Goin' Figs / Skip the Daizens.-forumrunner_20140429_110029.png
Clean..
Goin' Figs / Skip the Daizens.-forumrunner_20140429_110042.png
Lube
Goin' Figs / Skip the Daizens.-forumrunner_20140429_110100.png
Insert.. you don't need a shop press to insert the bushings, only to insert the metal shaft. And you wont even need that much pressure. As per install instructions you need to rub a small amount of grease on the inside of the bushing on the side that you will be installing the shaft from.
Old 04-29-14, 08:03 AM
Tank
Tank's Avatar
Goin' Figs / Skip the Daizens.-forumrunner_20140429_110221.png
Press in shaft..
Goin' Figs / Skip the Daizens.-forumrunner_20140429_110246.png
Done.
#2 Caster arm bushings next..
Old 04-29-14, 08:06 AM
jadu
live.love.laugh.lexus
Forum Moderator
jadu's Avatar
nicely done! I actually just went with Figs steering rack bushings and I could already feel the difference. All these bushings are gonna be a night and day difference
Old 04-29-14, 12:47 PM
Tank
Tank's Avatar
Yes, cant wait to see the difference. Steering rack bushings are next and then I should be done with the front end...for now..lol
Old 04-29-14, 04:36 PM
Tank
Tank's Avatar
Goin' Figs / Skip the Daizens.-forumrunner_20140429_193242.png
You might get stuck removing/inserting the camber adjustment bolt on eather side.. I loosened the steering rack mount bolts and was able to wiggle it in there.. just be careful with the tie rod boots.
Old 04-29-14, 04:48 PM
Tank
Tank's Avatar
Default Caster Arm bushing install
Goin' Figs / Skip the Daizens.-forumrunner_20140429_194434.png
Bushing pressed in..
Attached Thumbnails Goin' Figs / Skip the Daizens.-forumrunner_20140429_194420.png
Old 04-29-14, 05:06 PM
Tank
Tank's Avatar
Goin' Figs / Skip the Daizens.-forumrunner_20140429_200554.png
Finished product..
Old 04-29-14, 05:19 PM
Tank
Tank's Avatar
Attachment 326589
Finished product.. you shouldn't need the press to insert the metal shaft or the top and bottom parts of the bushing. I was able to press the rest of the parts in by hand which made it easier for me to re-install the arm. I ended up having to push the metal shaft back out about half way so I could thread the two mounting bolts on the LCA.
Old 04-29-14, 05:28 PM
Tank
Tank's Avatar
Goin' Figs / Skip the Daizens.-forumrunner_20140429_202010.png
KEEP IN MIND..just like the OEM bushings one side of the metal shaft has a smaller hole than the other. The smaller side belongs on the side of the caster arm with the R or L on it.
Goin' Figs / Skip the Daizens.-forumrunner_20140429_202023.png
The larger hole goes upward.
Goin' Figs / Skip the Daizens.-forumrunner_20140429_202045.png
Right side (passanger side) as it would be mounted on your GS.
Any questions feel free to ask.
Good luck.
Old 04-30-14, 07:29 PM
goodyonsen
goodyonsen's Avatar
nice. are you using their adjustable castor bushing model or just the regular one?
also thinking about getting the FIGS steering back bushing. i have a whiteline rack bushing waiting to be installed but im having second thoughts
Quick Reply: Goin' Figs / Skip the Daizens.
