RSR Coilovers
Old 05-12-14, 08:31 PM
young1026
young1026's Avatar
Default RSR down springs
How stiff will the ride become, and is it worth it? I don't want to get the super downs because of the possibility of rubbing. Will springs void my warranty?
Old 05-14-14, 10:55 AM
TheShaddix
TheShaddix's Avatar
The reason you didn't get replies is because your questions are all over the place. What is it that you're trying to do? Your thread is labeled coilovers, then you edited the content asking if springs void the warranty...Anyway, If you get coilovers, the ride will definitely be better than stock (depending on your stiffness setting). You can either set it to float or make it stiff, the difference is night and day, unlike the crappy factory system which everyone seems to like. Coilovers or springs will not void any warranty that is unrelated to suspension. In other words, if your coilovers leak, you're on your own. Or if the alignment gets out of spec, they won't do anything. They could give you some grief about the unplugged dampening motors for stock shocks which throw some codes in the system, so in case you get a check engine light, they might say it's partially due to that, but you just gonna have to argue them on that.
As far as rubbing, you will get that regardless depending on your wheel setup. If you keep them stock with some 20mm spacers, it will be minimal.
enigma65
03-05-12 05:18 PM
MrHarris
Suspension and Brakes
37
03-19-10 09:42 AM
jewel
07-20-06 12:11 PM
Aprazer
Suspension
12
04-28-06 11:31 AM
Quick Reply: RSR Coilovers
