Are upper ball joints replaceable?
Old 03-19-14, 03:16 PM
GSsportD
GSsportD's Avatar
The nut for the balljoints tightens to 64 ft. Lbs.
The 2 mounting bolts tighten to 39 ft. Lbs. But you can't really fit a torque wrench in there.
I didn't get an alignment after I installed the new UCAs and the steering felt the same, I'm not sure if you NEED an alignment....
Old 03-19-14, 08:34 PM
ttaylor993
ttaylor993's Avatar
Man does that look easy! I don't need to replace my UCA just yet. But, when time comes, I'll be ready. As for the alignment, since you're adjusting the camber, I don't see how you could not need an alignment.
Old 03-19-14, 11:55 PM
GSsportD
GSsportD's Avatar
You will only need alignment if you are going to use the aftermarket UCAs with adjustable camber but if you use OEM or Non adjustable UCAs I don't think it's necessary to get an alignment.
Old 03-20-14, 10:53 PM
DosyBoy
DosyBoy's Avatar
Great info guys!!!
Old 03-21-14, 03:40 PM
burny
burny's Avatar
Does a sport edition have a different control arm than non sport edition?
Old 03-21-14, 05:03 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
you mean UCA? then no. there all the same. control arm no. 2 got beefier in 2003 +
Old 03-21-14, 05:51 PM
burny
burny's Avatar
I notice when you go to buy upper control arm that it asks if you want with or without special edition. Any idea what that means? This is for a 2002 GS3
Old 03-24-14, 08:55 PM
DosyBoy
DosyBoy's Avatar
So I should buy an 03+ ? Does that include aftermarket also?
Old 03-25-14, 01:55 AM
tmf2004
tmf2004's Avatar
not sure about after market as they are probably made differently... I probably wouldn't go after market on these.. The price isn't terrible on Sewell's website... Its the UCA's that are priced out of this world..
Old 03-27-14, 09:03 AM
Metsfan
Metsfan's Avatar
The garage is telling me I need upper ball joint, lower ball joint, upper control arm, tie rod end, and an alignment—all on the passenger side only. They said everything on the driver's side is nice and tight. They said this isn't uncommon in the Northeast as the curb side gets most of the salt, sand, potholes, etc. They're telling me $775 with labor (using aftermarket parts). I think I could do all but the alignment myself, but this is a reputable garage and it seems like a good price. Any thoughts?
Old 03-27-14, 10:01 AM
tmf2004
tmf2004's Avatar
you could do it all your self . just pay for align ment .
Old 03-27-14, 10:33 AM
Metsfan
Metsfan's Avatar
Yeah, I'm leaning in that direction. I've done a lot of my own work (door actuators, brakes pads and rotors, hood release cable) and the DIYs make this work look like with the right tools and common sense, I could do it, I just don't want to get well into it and find I'm out of my depth. But, I guess that the risk when you're trying to save money. Thanks for your advice.
Oh, of the aftermarket parts, ACDelco is somewhat more expensive than the others, do you know if their parts are actually higher quality than, say, Moog? Thanks.
Old 04-06-14, 11:15 AM
foresure84
foresure84's Avatar
who can help me out with this
Returd
Suspension and Brakes
06-03-17 12:47 PM
O1GS43O
06-01-10 08:34 PM
frankjames
07-20-09 09:51 AM
n737nc
02-06-07 05:42 PM
cutlo400
06-25-05 06:07 PM
Quick Reply: Are upper ball joints replaceable?
