crub damage (driverside)
Old 02-26-14, 08:21 AM
tylerd1023
tylerd1023's Avatar
Default crub damage (driverside)
so a few weeks ago in virginia we got hit with our first snow storm of the year , well in the midst of the storm i had to run to the store for wood , for my fireplace , and for some food , well on m route home i made it about 95% of the way without a problem , and when i was making my right turn onto my road i actually hit a slight incline ( roads were covered in about 1" of snow ) the road wasnt perfectly flat
well i ended up sliding into the curb on my drivers side ( 10-15mph max) and came to a stop , ended up getting out and noticng no physical damage , so i backed off the curb , drove the car all of 1/4 mile down the road to my house and parked in my driveway . well about a week ago , we got hit with almost perfect weather ( 70 degrees) so i decided it was time to jack the gs400 up and pull the wheel off to start fixing the damage ,
i had already noticed the bent lower control arm so i had already had a replacement , well when pulling everything off i noticed a few things
1) lower control arm was bent towards the interior (3-3.5")
2) lower radius arm ( control arm #2) not noticable bent
3) bad lower ball joint
so i went on with replacing the lower control arm , so i could make steps towards the car being fixed, when i noticed while bolting everything back up , i had a bad ball joint , and the lower drivers side radius arm was bent so bad ,. if i placed the one end on the stud . i couldnt bolt the control amr to the lower control ar, so then i bolted it to the car with the bushing side dangling and noticed it has about bent about 1.2-2" . and the ball joint was bad as well
so my question is , where the hell can i find this lower radius arm , used if possible , but also new if it can be found at a fair price , it isnt a very easy part to come across hints why im asking in here before i go out and spend all this money replacing this part.
P/N: 48069A - ARM SUB-ASSEMBLY, FRONT SUSPENSION, LOWER No.2 LEFT. ARM ASSY, LWR NO.2 Left
there is also a diagram of this but i cant find it . its the arm the atached on the back side of the lower control arm , that has 2 bolts on the lower control arm underneath the strut mount , and bolts to the back of the wheel well atached to cars unibody..
if you hav a part for sale ( drivers side , lower raidus arm ( tension rod) you can contact me at 8045145252 by text or call becouse i am really trying to fix this issue
lexmoose
15
03-21-15 05:28 AM
CBGS3
03-05-14 06:15 PM
Brian Zado
15
02-06-07 07:33 AM
alexamparo
GS - 1st Gen (1993-1997)
17
01-07-03 04:53 PM
xgorjuicex
IS - 1st Gen (2001-2005)
26
01-05-03 03:07 AM
Quick Reply: crub damage (driverside)
