are SPC camber kit any good?
Old 02-22-14, 08:53 PM
naldo92
naldo92's Avatar
Default are SPC camber kit any good?
im planning on lowering my IS and of course ill need camber kit, but not sure witch one is a good camber i found the SPC cambers but not sure if they are any good...
Old 02-22-14, 10:39 PM
bboysunone
bboysunone's Avatar
Yeah. I think spc is pretty good. I got Megan before. But spc has better quality
Old 02-23-14, 05:47 AM
naldo92
naldo92's Avatar
thanks alot man
Old 02-23-14, 10:15 AM
e46m3lol
e46m3lol's Avatar
OP... Are you planning on slamming the car? If so I would not recommend the spc camber call joints. Reason why is because the spc ball joint will bottom out onto the upper shock tower whenever you hit or go over imperfections in the road. I go trough this everyday as I have them installed on my car.
Old 02-23-14, 10:22 AM
Gville350
Gville350's Avatar
^But you've got you admit you're FAIR lower than most folks out there! LOL
Anyhow, just because you're lowered doesn't mean you automatically NEED a camber kit. Toe will kill tires ALOT quicker than camber. How low are you planning to be? Are you on springs or coilovers? What size wheels?
Old 02-23-14, 10:27 AM
e46m3lol
e46m3lol's Avatar
Just threw some 20s on this morning and I can already tell I'm gonna hate the car. Rougher ride and rotational mass is a lot heavier compared to my 18" volk gramlights lol
Attached Thumbnails are SPC camber kit any good?-image-2069030772.jpg   are SPC camber kit any good?-image-2216669772.jpg
Old 02-23-14, 03:57 PM
joedad
joedad's Avatar
First get the Figs Engineering poly. bushings for the front #2 rear lower control arm. The factory front bushings are liquid filled and cause a lot of outward deflection during braking and other roadway conditions and cause a major inner tread wear. They (Figs) also offer an adjustable (+/- 0.5 degrees) upper control arm camber busking kit (won't interfere with the shock tower).. When you get aligned set everything (front and rear) as close to 0.0 degrees as you can.
Old 02-24-14, 03:54 AM
naldo92
naldo92's Avatar
im doin coils, im not goin that low i just want the fender to touch the tire and im kipping my stock rims 18"
Old 02-24-14, 05:13 PM
joedad
joedad's Avatar
Then the best bet for tire wear reduction would be the #2 lower control arm polyurethane bushing to reduce the "toe out" deflection during braking etc. and 0.0 degs. of toe front and rear.I tried 20" Vossens (stock suspension) and did not like the 20's at all, tire wear was horrendous. Figs has posts showing the difference between the stock "liquid filled bushing" and the poly. bushing, quite a remarkable video.
Old 02-24-14, 06:09 PM
jdmSW20
jdmSW20's Avatar
^^^^^^^^^^THIS
unless you plan on slamming out and aggressive wheel setup a camber kit isnt really priority. natural camber alone you should be fine
Old 02-24-14, 07:35 PM
joedad
joedad's Avatar
Lexus could have solved this problem by making a car where you could actually adjust the camber +/- 2 deg.s form the factory instead of having the camber staked and non-adjustable. They knew full well that Lexus owners were heavy into aftermarket suspensions and tires which needed adjustments, but, "oh no" they chose to leave us all scrambling for answers.
Old 03-16-14, 07:46 PM
LexusGuyyy
LexusGuyyy's Avatar
well, bringing this thread back, just purchased a set of CCW LM5 18x10.5 +3 front and 18x11.5 -7 and looking to put them on my 2IS, the guy whom i purchased the wheels from is advising me to purchase some Front and Rear camber kit, i already have Rear Toe, i just wanted to get clarification if i am needing those camber parts before i go purchasing them. they are also helping me as far as fender modifications.
Old 03-16-14, 08:06 PM
laobo979
laobo979's Avatar
Good luck even with the camber ball joint up front you gonna need hella work to fit the width and offset. Same goes with the rear even with a camber kit you need to widen your rear 1/4 fenders. Your probly need toe,camber,and lower arm.
Old 03-16-14, 09:00 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Post pics if you get them to fit. That front is wide.
Old 03-16-14, 09:05 PM
LexusGuyyy
LexusGuyyy's Avatar
i will definately keep you guys posted, maybe on a new thread somewhere, should be completed this weekend
Quick Reply: are SPC camber kit any good?
