Tokico Illumina Advanced Handling Kit for mk4 Supra
Old 01-21-14, 01:15 PM
tenac2215
tenac2215's Avatar
Question Tokico Illumina Advanced Handling Kit for mk4 Supra
ive been looking into suspension upgrades for my sc400 and came across the tokico illumina advanced handling kit for the supra. the kit comes with illumina struts and tokico lowering springs. i found a post about this kit on the club lexus forums, but its from 2003 haha. i was just wondering if i could get some more info about ride height drop on these, if the springs are already mounted to the shock, spring rates, and if i will have to worry about any tire rubbing, and if anyone else has any pictures of this kit on their sc, that would be awesome.
i have supra tt wheels with 255/40/17 rear and 235/45/17 front, but i do intend on getting 275/40/17 for the rear when i need new tires.
heres a link to the kit: http://www.raceinspired.com/p-6686-t...1994-1998.aspx
Old 01-22-14, 04:00 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I checked the link and continued my search with other sites. They are all posting the same thing. It appears they are to be close to OEM specs and would be a safe bet to say at least an inch drop, IMO. I also looked at the same setup on other cars, VW and Mustang, both close to a one inch drop if not more. For the money they seemed to have gotten good reviews for the quality of product. For your wheel and tire setup you should be golden, even running 275 in the rear. I have the same wheel setup and I am running a 275/40/17 in the rear. I am lowered on Esplier all the way around and have no rubbing issues, keep in mind I have the black metal trim/lip removed out of my fender wheels also. I also have 15mm ICHIBA spacers in the front and still no rubbing issues. When compared to what I have I think you should be able to run what tire size I have and these springs w/o any rubbing or future concerns, but maybe not low enough once settled. JMO.. Good luck on your choice and sorry I couldn't help you any further.
Old 01-23-14, 12:33 PM
tenac2215
tenac2215's Avatar
thank you! i figured i wouldnt have any issues with rubbing but figured id ask if anyone knew. do you know if i would i need new supra strut top hats or new sc top hats?
Old 01-23-14, 03:17 PM
Joey-E
Joey-E's Avatar
When you get these please post some pics of the drop!
Old 01-23-14, 08:17 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I am assuming since they will work in our SC, I am safe to say you can reuse the SC top hats. If you need to reorder them, then I would order the TT one's just to be safe. You might even want to cross match the numbers online.
Old 01-24-14, 07:25 AM
tenac2215
tenac2215's Avatar
good point, i will do that and let you know what i find.
Old 01-24-14, 07:30 AM
tenac2215
tenac2215's Avatar
just cross matched part #s online and it looks like SC300 / SC400 uses the same top hats as Supras!
Old 01-24-14, 02:47 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I was thinking they did. I wouldnt see why they would be different, but the PRICE !!!
Anything that says SUPRA, is triple in price!!!
Old 01-24-14, 06:23 PM
tenac2215
tenac2215's Avatar
are there any aftermarket strut mounts available? or are the oem ones pretty good already.
Old 01-24-14, 06:50 PM
GreenUZZ31
GreenUZZ31's Avatar
Stock JZA80 suspension is fairly low in a SC/Soarer...
Old 01-26-14, 02:54 PM
tenac2215
tenac2215's Avatar
crap, i might not want to get any lower than that. i wonder how low it will be with lowering springs
Old 01-26-14, 03:52 PM
GreenUZZ31
GreenUZZ31's Avatar
just get a set of new JZA80 koni's off summit and a set of stock supra springs
Old 01-26-14, 05:09 PM
Joey-E
Joey-E's Avatar
What lowering set up is this and do you have any more pics? I like this drop right here.
Old 01-26-14, 07:29 PM
GreenUZZ31
GreenUZZ31's Avatar
Stock JZA80 billsteens
Old 01-26-14, 09:27 PM
Joey-E
Joey-E's Avatar
With stock TT Supra springs?
Quick Reply: Tokico Illumina Advanced Handling Kit for mk4 Supra
