Swaybar endlink bolts
Old 01-14-14, 07:16 PM
sc4jms
sc4jms's Avatar
Default Swaybar endlink bolts
Well this is more a precaution for anyone...I took the the gs out for a spin and turned the corner and something just didn't feel right. So pulled over and checked and everything seemed alright but w the help of my lil led flashlight it turns out my driver side endlink mouting bolt to the swaybar was missing. The swaybar wasn't broken just separated from the endlink. Im not sure how it happened just glad nothing else went wrong.
IF YOU HAVE THE TIME MAKE SURE ALL SUSPENSION BOLTS ARE TIGHT. IT IS VERY EASY TO OVERLOOK THE SMALL STUFF.
Old 01-15-14, 05:14 AM
SprtDesign
SprtDesign's Avatar
That happen to my pass. side before. Moog endlinks bolts are no good. the 12mm nut worked it's way off and was nowhere to be found. I replaced with an OEM bolt and so far so good. I will replace with Figs links when I get around to it.
Kiai808
Suspension and Brakes
04-19-19 03:20 PM
hsmac
RX - 1st Gen (1999-2003)
29
04-14-16 09:33 PM
Hayk
05-06-12 11:56 AM
2IS350DT
03-11-11 02:32 PM
BLKonBLK98
10-11-09 05:12 PM
Quick Reply: Swaybar endlink bolts
