|| FIGS Engineering 3rd Gen IS Suspension and Brake Development Thread || - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 08-04-14, 10:39 PM   #16
sam430
sam430's Avatar
Quote:
Originally Posted by FIGS View Post
so similar they share a part number
a complete replacement? maybe something similiar to this but without the screw on thingy?
sam430 is offline   Reply With Quote
Old 08-04-14, 11:03 PM   #17
Silec
Quote:
tein with swift springs and lca replacement?
Silec is offline   Reply With Quote
Old 08-05-14, 07:55 PM   #18
sam430
sam430's Avatar
No...just throwing idea on the lca. One solid unit like above.
Old 08-18-14, 10:29 AM   #19
Silec
Any updates?
Old 08-18-14, 01:27 PM   #20
FIGS
The Maker
FIGS's Avatar
still trying to get to it. the LCA would need to be converted tocoilover, which we might do as well and ditch the pocketed coil. I can probable get the camber correction first, then VIP will be more involved.
Mike
__________________
<a href=http://www.figsengineering.com target=_blank>
Redefining Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR-KW-PENSKE-OHLINS
LINKS-ARMS-BUSHINGS
BBK's, Carbotech pads
OS GIKEN
FABRICATION
PPE Master Distributor. Headers/Exhaust
Instagram @FIGSENGINEERING
FIGS is offline   Reply With Quote
Old 08-19-14, 07:39 AM   #21
NVMarkus
NVMarkus's Avatar
So any big brake kit yet?
NVMarkus is offline   Reply With Quote
Old 08-19-14, 01:27 PM   #22
FIGS
The Maker
FIGS's Avatar
Quote:
just the front still. The rear we are waiting to get the IS-F kits released before we start another development. If you are interesting in placing an order, we can develop a 4 corner kit.
__________________
LINKS-ARMS-BUSHINGS
OS GIKEN
FABRICATION
Old 09-06-14, 04:38 PM   #23
mello03
mello03's Avatar
I need some rear camber arms How's it coming?
mello03 is offline   Reply With Quote
Old 09-07-14, 10:40 PM   #24
FIGS
The Maker
FIGS's Avatar
Still on the side burner. Might have the n1 racecar in a few weeks so I will see if we can knock it out then.
__________________
LINKS-ARMS-BUSHINGS
OS GIKEN
FABRICATION
Old 09-08-14, 06:16 AM   #25
mello03
mello03's Avatar
That'd be awesome. I guess them being on the side burner is better than on the back lol. Waiting for these before I go with new tires.
Old 12-17-14, 01:13 PM   #26
FIGS
The Maker
FIGS's Avatar
We have opened our preorder as well and we will have both upper links with the same options we have on the 3GS which is camber correction or negative camber. The #2 arms will eventually get polyurethane bushings. We should be able to support a wider range of adjustment on this arm in our version.
Thanks Mike
http://shopfigs.com/v1/index.php?rou...product_id=280
3IS 4 GS rear upper links. Camber kit
__________________
LINKS-ARMS-BUSHINGS
OS GIKEN
FABRICATION
Old 12-17-14, 04:00 PM   #27
Fingers007
Fingers007's Avatar
Thanks Mike
Thank you!!!
Fingers007 is offline   Reply With Quote
Old 12-20-14, 01:00 PM   #28
ultran00b8
Thanks! Will preorder ASAP.
ultran00b8 is offline   Reply With Quote
Old 12-20-14, 10:03 PM   #29
bucanero
Will the front be available the same time?
bucanero is offline   Reply With Quote
Old 12-21-14, 09:47 PM   #30
FIGS
The Maker
FIGS's Avatar
bucanero, the front LCA bushing is common with the 2IS and we have proven it to be the primary cause of tire wear. If more negative camber is desired we already have a custom design we can use.
Mike
__________________
LINKS-ARMS-BUSHINGS
OS GIKEN
FABRICATION
Thread Thread Starter Forum Replies Last Post
Complete Diff bushing kits now available. Multi-piece design for the SC FIGS Performance & Maintenance 12 06-15-16 09:20 AM
New Product: Drop Tie Rod Ends GS SC LS FIGS Club Lexus Vendor Marketplace 1 02-01-14 08:44 PM
Rear Knuckle LCA bearing for the IS, GS and SC FIGS Club Lexus Vendor Marketplace 0 11-07-12 05:29 PM
FIGS Mat-Saving CNC Footplates are back in stock FIGS Club Lexus Vendor Marketplace 1 08-14-12 12:11 AM
Can someone tell me where these FIGS Rear Pinion Mount Polyurethane Bushing goes? justablkv8 GS - 2nd Gen (1998-2005) 1 03-15-12 08:09 AM
Tags
arm, bushing, control, front, is300, lexus, lower
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
