Mixing brake fluid?
Old 12-20-13, 11:50 AM
Loyalone72
Loyalone72's Avatar
Default Mixing brake fluid?
I did some research on the boards and found that Castrol LMA brake fluid is used by some and is ok to mix with our existing fluid. What they sent me doesnt say LMA on it. Its DOT 4. Is this ok to mix with the existing fluid?
Amazon.com: Castrol GT LMA Brake Fluid - 32oz. 12504: Automotive Amazon.com: Castrol GT LMA Brake Fluid - 32oz. 12504: Automotive
Old 12-21-13, 05:08 PM
RamAirRckt
RamAirRckt's Avatar
DOT5 can't be mixed, but DOT4 and DOT3 can, but performance will be lower is moisture is present. Without you will never know the difference.
Old 12-24-13, 10:55 AM
Loyalone72
Loyalone72's Avatar
Got this response from Castrol Customer Service.
Castrol Contact Centre <contactus@bp.com>
6:43 AM (4 hours ago)
to me
--Please enter your response above this line--
This ticket has been updated by IC - Castrol Representative
Thank you for contacting Castrol.
The Castrol GTLMA brake fluid has been renamed to the Castrol Brake Fluid Dot 4. The packaging and the name have changed but the product is the same.
Castrol's line of Trasnsmission fluids, Gear Oils, Greases and Brake Fluid underwent a name change to align the products with some of the European products but the products remain the same.
Castrol Brake Fluid Dot 4 combines both DOT 3 and DOT 4 performance and exceeds both specifications.
Castrol Consumer Relations
abs
05-03-19 09:15 PM
RageRacerM
Suspension and Brakes
11-20-18 08:05 AM
matts6887
RX - 1st Gen (1999-2003)
20
04-19-16 06:40 PM
ToyotaLexus
02-16-09 07:46 PM
Quick Reply: Mixing brake fluid?
