If you have lowering springs would you help me?
Old 11-14-13, 05:08 AM
FlakJacket
FlakJacket's Avatar
Default If you have lowering springs would you help me?
I need some help from the Club Lexus community. I have a 2001 GS430 and am looking to buy some lowering springs. There is a lot of helpful pictures on this forum but I would like some actual numbers. If you have a GS430 with either the Eibach, Swift, or the H&R lowering springs and have just 2 mins you can help me greatly.
I would even accept a GS400 and last choice a gs300. I need the measurement from the center of the wheel to the edge of the fender in the front and rear. I ask this because it eliminates the tire, wheel, and camber combinations from the equation.
Please post the model and the dimensions. Getting a consensus would be very helpful to me so if the same combo is already posted still post to confirm actual numbers. If you also know someone that is still active on here and they may not see this can you please let me know so I can PM them directly.
For example my car
2001 GS430 Stock Springs F=15.5" R=14.5"
Local car
2000 GS400 Eibach Springs F=14.125" R=14"
I post this because Eibach advertises 1.2" and 1.2"
Old 11-14-13, 05:49 AM
kit cat
kit cat's Avatar
try searching within this thread. I couldn't find any with those springs you listed and with stock wheels but should be resourceful.
Old 11-14-13, 07:41 AM
FlakJacket
FlakJacket's Avatar
I have looked at all 18 pages more than once, but there are only pictures and some even are posting pictures of other peoples cars not really knowing the true setup. For example there is a supposed DF210 sprung car that clearly is sitting way to low in the back to be a DF sprung car and was not posted by the owner of the car.
Other forums that I frequent post the distance from center of wheel to fender because this eliminates the different wheel and tire combo that everyone runs and shows the true height of the spring setup.
Old 11-14-13, 12:48 PM
clos430
clos430's Avatar
I have a 05 GS430 on L-tuned springs F= 14" R =14"
Old 11-14-13, 12:59 PM
FlakJacket
FlakJacket's Avatar
Perfect. Thanks. I saw your car in another thread and liked how it sits. That's what I'm shooting for. I just couldn't make a comparison because i didn't see the tire size.
Old 11-14-13, 09:21 PM
clos430
clos430's Avatar
I'm running 245/35/20 front 275/30/20 rear.
Old 12-10-13, 11:28 AM
silverbul
silverbul's Avatar
here's pics of my car. 98GS400 with factory chrome 18' staggered rims. Only dropped the front so far. Eibach springs with 1' drop with bilstein struts. 1st 2 pics are before & other 2 is after. This way you'll have a general idea how it'll look
Attached Thumbnails If you have lowering springs would you help me?-imag0390.jpg   If you have lowering springs would you help me?-imag0746.jpg   If you have lowering springs would you help me?-2012-05-13-13.58.45.jpg   If you have lowering springs would you help me?-2012-05-13-13.59.17.jpg
Old 12-11-13, 10:02 AM
FlakJacket
FlakJacket's Avatar
Thanks everyone. I ended up getting a used set of H&R's. Thanks
Lexo_Tony
Suspension and Brakes
01-22-15 01:39 AM
kingkirby
11-11-08 04:11 PM
Quick Reply: If you have lowering springs would you help me?
