Vibration at 70+
Old 10-31-13, 08:36 PM
mikobangz
mikobangz's Avatar
Default Vibration at 70+
Hey everyone,
I'm having vibration at 70MPH+. The passenger seat back clearly vibrates and I can feel my lower seat vibrating as well. I've been reading that it could be the steering rack bushing, engine mounts, or alignment. Is there a way I can narrow down exactly which it is to save money?
Old 11-01-13, 01:02 PM
k7q
k7q's Avatar
Could also be rims not balanced right.
Old 11-02-13, 11:03 AM
SC4Paulo
SC4Paulo's Avatar
Whenever you have a vibration get your wheels balanced, if it still continues get your bushings in your steering rack, control arms, and other suspension components checked. When I had a vibration coming from my front right i took it to a local shop I trust and asked the mechinic what it could me, we jacked the car up and checked ball joints and etc by shaking the wheel left and right and up and down, when we moved to the right front we can clearly see the wheel moving and hear the tapping noise, looked at the steering rack and saw it moving and tapping onto the bracket, my bushings were shot. Not saying that its your rack bushings but just check over the suspension components piece by piece after you get the car balanced. If your suspension components and tires check out ok then you may have a problem with your driveline but you should feel it gradually get worse and worse the faster you go. as for motor mount and transmission mount youll feel vibrations as soon as you start the car and drive. I have had experience with shot tranny and motor mounts too -__-' usually you might as well replace all three so everything lines up well. If you do end up needing new items go try sewell lexus and use the Clublexus discount code, tranny and motor mounts should only come out to around 200 shipped.
Old 11-02-13, 02:36 PM
sc4jms
sc4jms's Avatar
just wanna chime in..i had the same issue with the vibration around 65 mph. my issue was solved with balancing of the rear tires. problem corrected.
Old 11-03-13, 06:19 PM
mikobangz
mikobangz's Avatar
Thanks for the input guys! I'll have my mechanic check it.
Bon
08-13-21 07:51 PM
Moarpower
12-17-18 09:26 AM
aamir007
Suspension and Brakes
08-27-12 10:53 PM
BoostAddct
17
10-28-11 09:29 PM
Jujharoo
11-12-04 01:23 AM
Quick Reply: Vibration at 70+
