Last edit by: IB Advertising
Browse all: Steering and Suspension
- How to Install a Lowering Kit
Step by step instructions for do-it-yourself repairs
RS*R Down Lowering Springs vs Super Down
#272
Your #1 Lexus Vendor
Contact us for your set!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#273
I installed Tein H-Techs on mine. I wanted to go for a conservative drop. Was going for that premium factory look. Nothing slammed. I have to say the car looks quite perfect. I'll post up some pics this weekend.
#274
Has anyone had RSR Down installed on a 3IS AWD for over 1 year? If so ha you have issues with vibrations and Blown shocks and axles? I just got a Is250 Fsport and i'm not ready to **** it up yet.
#275
I've had mine on for 15 months now and NO problems. Rides just like the day they were put on. And yes my car is AWD
#276
-Josh
__________________
Orange County, CA
Orange County, CA
#277
#278
-Josh
__________________
Orange County, CA
Orange County, CA
#279
Rear camber kit needed?
Not able to find a definite answer, but lowering on Downs, with 20mm spacer in the rear and 25mm up front, would I need to install a camber kit in the rear? Mine's a RWD
#280
I don't have experience with this particular mod on this car but I see no reason why you'd need a camber kit with that set up. Are you talking about clearing the fenders? I think plenty of people with stock f sport wheels, lowered run spacers and clear just fine (with 20mm) I think i've even seen 25mm.
#283
Hey everyone - I just had my RS*R downs removed and the OEM springs installed back into my '14 IS 350 F Sport AWD. Unfortunately, I am now experiencing some clunking sounds and harsh vibrations when going over minimal bumps. I only had the RS*R downs on the car for 3 months and ~ 3000k miles. Anyone have experience with this issue or suggestions as to why I am hearing these sounds? Much appreciated!
Update: found the issue. Rear sway bar link was loose. Nothing to see here
madenz (03-04-17)
#285
Hi Guys
I'm new here so I wanted to say Hello to everyone
I have an IS200t rwd F-Sport MY2016 (prelift) and I want to lower it a bit. I wanted to go after your advices and get RS-R spring kit, however there is also another option. Do you have any experience with Triple S Suspension https://www.facebook.com/media/set/?set=a.792402564253956&type=1&l=a685b5d1b9 ? Will they be fine? They are about to lower a bit more than RS-R Half Down and bit less than Down (I suppose) - Triple S tells that the drop will be c.a. 25-30mm
WDYT??
Getting back to RS-R. I totally like the F-Sport OEM suspension working with stock 18x8j and 18x8.5j wheels. I wouldn't like to change tha handling at all. Will the RS-R springs make the car more soft and comfortable loosing the performance while cornering and braking?
RS-R specs
The same question for Triple S?
Thanks
Soldat79 (09-21-21)
