Old 12-12-14, 03:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
RS*R Down Lowering Springs vs Super Down
Old 04-11-16, 03:03 AM
  #256
ph0nzie
ph0nzie's Avatar
Originally Posted by asiandavid
Theres a lot of forums on how to adjust the lights all you would need is a Philips screw driver and on the back of the head light there is teeth s that will move as you turn the screwdriver
Adjusting the headlight height is easy. All you need to do is park in front of a wall on a leveled platform. I personally drove to my bank, located in a plaza. It was a nice flat parking lot. I faced my headlights towards the wall and was able to balance both headlights to point straight across. Not too high. Not too Low. And all you need is a Phillips screw driver. There is a white contraption located near the headlight. Look close as you can see where you are able to turn a dial. Ideally using a Phillips screw driver. It will take a few turns to see a noticeable change in height. But it is very simple. Experiment before paying someone. Just my opinion. If you get this wrong. You should not be working on cars ever.
Old 04-11-16, 06:36 AM
  #257
Chump408
Chump408's Avatar
I did it over the weekend myself. The mistake I made looking all over is that the threads that popped up would be a different Lexus model hence a slight confusion on my part. However, after popping my hood I realized how easy it was to access the plastic piece.
Old 05-17-16, 08:39 PM
  #258
eR1k
5th Gear
eR1k's Avatar
AWESOME, although some of the pictures arent viewable anymore
Old 05-17-16, 08:44 PM
  #259
eR1k
5th Gear
eR1k's Avatar
Originally Posted by charmander
Here is my 2015 Atomic Silver on Rioja lowered on RSR Down springs and 20mm spacers.
picking up the same colour combo in 2 days!
Old 05-30-16, 10:43 AM
  #260
ISOhana
ISOhana's Avatar
Default wheel size
Originally Posted by xavfab06
RSR DOWN SPRINGS
What is your wheel/tire size and et?
Old 06-07-16, 01:33 PM
  #261
RayHdez911
RayHdez911's Avatar
RS-R Superdown
19x8.5 Front
19x9.5 Rear
Taomuoncoi (01-24-21)
Old 06-07-16, 03:58 PM
  #262
SceneAmati
SceneAmati's Avatar
Here's mine freshly lowered on RS*R Downs...
Stock Wheels. Velgen VMB5 19's on the way (thursday I hope)
Old 06-08-16, 01:04 PM
  #263
LexCeeTee
LexCeeTee's Avatar
Can anyone comment whether 25mm spacer on stock wheels w/ RSR downs would rub at all? I combed through and couldn't find that scenario.
Old 06-08-16, 09:15 PM
  #264
Kwong516
Kwong516's Avatar
This is perfect! Cant wait to get my set
Old 06-08-16, 09:17 PM
  #265
Kwong516
Kwong516's Avatar
I feel like 25mm would be too much on the downs. 20mm would be perfect with rsr down which is what I would be doing to mine.
Old 07-04-16, 10:51 PM
  #266
387
387's Avatar
I am sitting on an set of RSR Downs for an AWD.
From what I understand, with the same model spring, because of the differences front struts, an AWD model will always sit higher and Downs have higher spring rate than Super Downs, which are too soft and bottom out easily.
How much more travel does an AWD have up front?
Old 07-14-16, 05:16 PM
  #267
387
387's Avatar
I picked up a set of Superdowns, so I am sitting on both those and the Downs.
After much thinking and looking at pictures, am 99% sure I am getting the Superdowns installed next week. If my car was RWD, the Superdowns would be too low and the Downs almost alright, but I have an AWD. This is a DD (including winter i.e. snow) and needs to make it over speedbumps and parking entrances easily. As long as the underside of the car doesn't scrape or the exhaust, I am good.
I am assuming AWD have more front strut travel than an RWD and that there is more than 0.75" until it meets the bumpstop over the RWD.
I can't wait to get rid of this 4x4 status.....
Old 07-25-16, 03:09 PM
  #268
EffSport
EffSport's Avatar
Default Looking to buy used RSR Superdowns for 2016 IS350
If anyone is selling RSR Superdowns for a 2016 IS350, please PM me. I'm in San Jose, CA. Thanks!
Old 07-29-16, 11:55 AM
  #269
jio
jio's Avatar
Default back to stock
i have a set of RSR super downs on my is250 F sport that i want to trade straight up for stock springs. Trading the car in and cant find my stock, will also throw in a full set of 20mm H&R spacers. Im local in fort lauderdale, Fl so PM me
Old 08-02-16, 07:08 AM
  #270
cooperyau
cooperyau's Avatar
Is it true that the down or super down springs will wear out the oem struts quickly after one year? I have a 3 year lease so hoping the struts would last this long with the RSR down springs. ;-P
Quick Reply: RS*R Down Lowering Springs vs Super Down
