Old 12-12-14, 03:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
RS*R Down Lowering Springs vs Super Down
Old 03-25-16, 09:28 PM
  #241
asiandavid
asiandavid's Avatar
does anyone have pics wirhy super downs with a front lip i want to see how low itll be with a font lip/splitter
Old 03-26-16, 03:55 AM
  #242
Chump408
Chump408's Avatar
On the superdowns you may want to get a cheap lip. I have a steep driveway so I scrape every time I exit. But if you don't, you may be okay. But here's mine dropped on superdown with a cheap eBay lip
Old 03-26-16, 01:07 PM
  #243
asiandavid
asiandavid's Avatar
Your side shot is perfect the light helps show the drop and with the lip look like maybe 1 to 2 inches off the ground lol do you scrap often i was planning on superdowns and aimgain reps of ebay
Old 03-27-16, 12:30 PM
  #244
Chump408
Chump408's Avatar
I scrape all the time leaving my driveway. Which is why I got a cheap eBay lip. It's already damaged. But other than that I don't scrape too often, I drive pretty safe often when going over speed bumps. Here's a better side shot to give you an idea how low the front is
Old 03-27-16, 12:45 PM
  #245
asiandavid
asiandavid's Avatar
Wink
Tganks for the info and pucs when you say damage is it just scrapes or is it cracked? And if possible can you take a close up of how close the front lip to the ground is?
Old 03-27-16, 12:52 PM
  #246
Chump408
Chump408's Avatar
Scraped, that's all. I'll snap a photo for you later
Old 04-04-16, 11:54 AM
  #247
thang87
thang87's Avatar
Originally Posted by ultran00b8
The drop is correct as the car comes with reverse rake from factory. Why RS*R chose to accentuate this, I do not know. But from the specs, you can see that they didn't do much to reduce the factory reverse rake.
Maybe it's to ensure that there will be no rubbing during full lock over bumps?
Stock: 1 Finger rear, 3 finger front (On 19's)
RS*R Down: Flush rear, 1.5 finger front
Just freshly lowered on RS*R Down Springs...
Hi Tran, i currently have a 2016 Red IS350. I really love to have that 19 inches Fsport wheels like yours. Would you please tell me the cost of wheel and installation and also the link to these wheels if you buy it online.
What springs did you use to drop your car ? Is it Fsport or RSR down or super down ?
Thank you!
Old 04-05-16, 04:01 PM
  #248
sdotk
sdotk's Avatar
How much should I pay for installation? I was quoted 160. Should I negotiate down? It seems pretty expensive
Old 04-05-16, 08:41 PM
  #249
Chump408
Chump408's Avatar
$160 is the norm. I paid $200 for install of springs, camber kit and spacers
Old 04-05-16, 08:46 PM
  #250
asiandavid
asiandavid's Avatar
Got it drop gesture day for 160 still waiting on spacers and idk if I want to spend more on camber kits yet I wanna see how bad the tires wear down
Old 04-05-16, 08:48 PM
  #251
asiandavid
asiandavid's Avatar
Chump408 have you rubbed yet with the rear I heard with 20mm in the rear if you pack people or go over dips/bumps it'll rub. If you have how bad was it?
Old 04-05-16, 08:49 PM
  #252
Chump408
Chump408's Avatar
It rubs only when I have 2 passengers in the rear but it is a slight rub. Other than that when I drive alone I never rub.
Old 04-05-16, 08:51 PM
  #253
asiandavid
asiandavid's Avatar
Yeah that's what I was afraid of when I got out with friends they all go in my car lol would i be rubbing as you drive with 2 in the rear or just when dips/bumps
Old 04-09-16, 12:31 PM
  #254
Chump408
Chump408's Avatar
For those who have the Superdowns installed, I'm sure you all are experiencing the issue with the headlights pointing down after install. I can see only about 10-15 feet in front of me while driving at night. So today I wanted to get that problem fixed. Went to 2 dealerships and 1 refused to work tamper with the headlights because they didn't want to be liable for any mishaps. Dealership 2 said it would cost about $260 to play around with it and not guaranteeing it'll fix the issue because of the sensors possibly trying to readjust itself.
I read through this whole thread again and only on page 6 it mentions a solution but it wasn't too descriptive. Did a search on the forum and came across a few pages but it was for other models so unsure if it applies to the IS. If someone can guide me with either directions of a picture diagram on how to adjust the height, I would greatly appreciate it or chime in with your own experience.
Old 04-09-16, 12:35 PM
  #255
asiandavid
asiandavid's Avatar
Theres a lot of forums on how to adjust the lights all you would need is a Philips screw driver and on the back of the head light there is teeth s that will move as you turn the screwdriver
Quick Reply: RS*R Down Lowering Springs vs Super Down
