Last edit by: IB Advertising
Browse all: Steering and Suspension
- How to Install a Lowering Kit
Step by step instructions for do-it-yourself repairs
RS*R Down Lowering Springs vs Super Down
#212
left front -1.1
right front -1.3
left rear -2.0
right rear -2.0
only the right front is out of spec (-1.2 is max)
hope this helps. my car is AWD
right front -1.3
left rear -2.0
right rear -2.0
#214
According to the sheet provided by the alignment shop,and these are AWD specs RWD might be different
right and left fronts are +.3 to -1.2 degrees
right and left rears are -.9 to -2.4 degrees
#215
I was on down springs and with the proper alignment I can attest that I was able to get 24k out of my first set of tires. Unless you are running some seriously aggressive camber, you should be fine. I actualyl have a set of down springs that Ill sell cheap. Ive traded my 3gIS 350 F for an RCF. PM me if interested.
#216
My 2016 IS200t on RSR down springs and 15mm spacers all around.
Taomuoncoi (01-24-21)
#219
This is just a quick shot after my car was lowered yesterday on down springs
Attachment 305917
*Sorry car was dirty*
Attachment 305917
#221
Sorry this may have been answered somewhere in the 15 pages prior, but for a 2014 2IS on dubs 9.5, would down springs rub or should I just stick to some half down springs?
#222
RSR Downs and Super Downs
Hey guy I'm new on here. I got a question , alright so I'm having an issue my car is still stock height and K3 Projekts wants to put some wheels on it. The problem is that they are 20x10 all around and I need a decent drop that won't rub or damage the car. Has anyone done that before ?
#224
dam the drop looks dope af. i was debating on the 2 and being in socal theres alot of dips and bumps and for a dd idk how i feel about runing these spring. how bad is it going over speed bumps and dips do you scrape anything under the car (exhaust, brace, etc)
#225
Not going to lie to you, when It's myself and 3 grown adults in the car, I do get some rubbing in the rear when going a bump, but that rarely happens, I'm in love with the look of the car, I haaaate wheel gap, and these springs did it for me. As for the bumps Miami doesn't have the greatest roads either, just have to see it and slow down a bit, and that's all. I highly recommend them if you want to go the "springs" route.
