Old 12-12-14, 03:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
RS*R Down Lowering Springs vs Super Down
Old 04-10-15, 10:04 PM
  #166
BOBFSPORT
BOBFSPORT's Avatar
Originally Posted by Megaman
Which springs fix the reverse rake in the car the best?
Tanabe NF210s do but i found the front spring rate too soft (as did others) so now I'm running RSR Downs up front and Tanabe NF210s in the rear and the car is sitting positive. Im still not so sure that this benefits handling as most street cars nowadays are designed with a little negative rake but if you like the look of your front lower than the rear I've found this to be the best setup.
bobbyexe (09-19-21)
Old 04-10-15, 10:08 PM
  #167
BOBFSPORT
BOBFSPORT's Avatar
Originally Posted by DENNiiEE
Defiantly going with RSR Down with 20mm spacers, but I do have the same questions like everyone else. How is the tire wear and do you need the camber to be adjusted after installing the springs.
I would actually advise against any camber kits and adjustment as I've seen it cause more harm than good (mainly in the form of rubbing). You should be able to get within spec or damn near close to it with Rsr Downs and not have any crazy excessive tire wear.
Old 04-13-15, 06:01 AM
  #168
Maveri9720
Maveri9720's Avatar
What about with super downs? I plan on keeping the stock F-Sport 18's, dropping with the super downs and using 20mm spacers all around. I was already planning on a camber kit, based on others alignment readouts. Thoughts?
Old 04-14-15, 06:46 PM
  #169
andy1gg
andy1gg's Avatar
My experience with RSR down springs are mixed. Car rides exceptionally well as for comfort but handling has suffered slightly. Seems like they are softer than the factory F-Sport springs. Body roll is more evident. Overall they are not bad but you cant expect much from just lowering spring.
Old 04-14-15, 07:47 PM
  #170
Jbreezie
Jbreezie's Avatar
It smells like body roll has improved for me. I hit the same corners at the same speed and it feels like it doesn't roll as much. It it softer going over bumpers though. I just got it so maybe it needs to settle in. I wonder when i should do the alignment? Maybe this Saturday. A week has passed 300+ miles.
Old 04-14-15, 07:53 PM
  #171
andy1gg
andy1gg's Avatar
No need for alignment drop is very moderate and since u don't have adjustable camber kits it's useless
Old 04-14-15, 08:26 PM
  #172
criticalgt
criticalgt's Avatar
You need to adjusts the toe tho...
Old 04-15-15, 09:22 PM
  #173
Megaman
Megaman's Avatar
So, in short, springs really arnt worth it. Spending the money on coilovers is the way to go.
Old 04-16-15, 07:36 AM
  #174
ddvette9
ddvette9's Avatar
Swift springs are worth it. Linear springs with performance AND function in mind. Look up their reputation, it's flawless for the most part. I have them and don't regret not going coils at all.
Old 04-16-15, 01:14 PM
  #175
criticalgt
criticalgt's Avatar
Coilovers + Swift
Old 05-04-15, 03:43 PM
  #176
CalvinXxxx
CalvinXxxx's Avatar
Anyone know if there are differences between the down spring for RWD and AWD? The official site says that the AWD version drops the rear a bit lower then the RWD version. Does it matter which version I got for my RWD 3IS? Thanks!
Old 05-05-15, 06:16 AM
  #177
Napalvr
Napalvr's Avatar
Supposedly the spring rates are quite different. I was going to try the half downs on my AWD knowing that they are for RWD and RSR told me that they would advise me not to. If I were you go with the version meant for your car. Just my .02
Old 05-07-15, 06:48 AM
  #178
OFFICIALis
OFFICIALis's Avatar
Will be installing rsr downs and will post pictures after its done AWD model
dappy9 (02-18-21)
Old 05-07-15, 02:01 PM
  #179
Napalvr
Napalvr's Avatar
If all goes well,I'll be following your lead. Please take good pics of the rear,which is my only concern.
Old 05-08-15, 06:39 PM
  #180
lexi90
lexi90's Avatar
+1 I also want to get them RSR Down Springs. I'll wait for your pictures!
Quick Reply: RS*R Down Lowering Springs vs Super Down
