Where to buy oem calipers? Anyone selling?
Old 08-26-13, 05:26 PM
Lukas99GS
Lukas99GS's Avatar
Default Where to buy oem calipers? Anyone selling?
One of my front calipers is jammed and I figured I'd replace both, called lexus and they cost 420$ each which is ridiculous, I saw some used for 110 for both fronts on eBay but idk if I trust that, anyone know where I could get oem cheaper? Or if anyone uses aftermarket calipers and how well they've worked for you
Old 08-26-13, 10:05 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
you could try the parts store or simply upgrade to the Supra Calipers.. You can find them on ebay.. if your worried you can always buy a rebuild kit..
Old 08-27-13, 02:06 AM
Lukas99GS
Lukas99GS's Avatar
Found some oem new on parts.com for 270$ ill keep looking but may go with that, supras calipers are interchangeable then? Or are GS calipers the same as all lexus models from back then?
Old 08-27-13, 06:58 AM
NorthStyle
NorthStyle's Avatar
You should check Rock Auto
Old 08-27-13, 10:00 AM
newgsman
newgsman's Avatar
I am using some no-name brands I picked up locally and so far (about a couple of months) I have had no problems. They are rebuilt and cost about $100ea. I think the only thing you have to really worry about with rebuilt ones is the durability of the seals that they use. Everything else on a rebuilt caliper is pretty much the same as oem (except maybe the pistons). If you do your routine maintenance and regularly clean and lube them up I would think they would be fine.
GaaraOTS
IS F (2008-2014)
09-17-18 01:19 PM
aring87
Suspension and Brakes
02-19-16 01:00 PM
TooCool4u
13
02-27-13 02:28 PM
UpstateLex
11-14-11 03:29 PM
Quick Reply: Where to buy oem calipers? Anyone selling?
