Question Regarding Rack and Pinion
My searches have not yielded what I'm wanting to know.
Car: 97 SC400 with a reman'd rack n pinion that was replaced 15k miles ago before I bought the car.
Problem: With engine off moving steering wheel side to side a clunk can be heard and felt in the wheel. Tie rods are tight. Found that the rack piston has play in it. Car drives like crap also but there are other contributing factors as well.
Question. Was told by a retailer that sales reman'd rack and pinions that the rack can be adjusted to get rid of the play. He said the adjustment nut was on top of rack near where the column attaches.
Is this true?
Thanks.
Is this true?
Thanks.
Yep. Originally thought the drivers side was bad but after removing the boot found it to be tight and noticed the play in the piston when shaking the wheel back and forth. It doesn't leak. I called the shop in Florida that replaced it and I've exceeded the mileage warranty by 3k miles. Don't wan't to buy another rack if I don't have to.
Most re manufactured racks have a life time warranty on the rack but not the labor to replace it. Unless they put in one from Toyota which is 1 yr and 12K miles but at more than twice the price.
I just had mine replaced by a local shop ........
Requires a wheel alignment, too.
1JZ Single SC400
DJ8684
GS - 1st Gen (1993-1997)
08-10-14 02:47 PM
