How to properly replace calipers?
Old 08-24-13, 02:53 PM
Lukas99GS
Lukas99GS's Avatar
Default How to properly replace calipers?
One of my front calipers has been jammed a long time and now it's making a squeaking noise, I just wanna replace both of them but no way I'm paying lexus like a grand to do it, I guess what I mostly need to know is do you have to bleed the brakes and how to go about doing that?
Old 08-24-13, 07:14 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
some great informational videos on youtube of how to bleed and replace brakes..
Old 09-07-13, 03:03 PM
PHML
Master Thread Closer!!
PHML's Avatar
yeah, check youtube on how to rebuild your calipers....and bleeding the brakes.
Old 09-09-13, 11:28 AM
VWTim
VWTim's Avatar
I bled the brakes on my '00 GS3 per the tutorials on here, key on, let the ABS pump do the work, etc. And never got a good pedal. I found in the Techstream software they have a brake bleeding utility, seemed to do a MUCH better job that I could manually.
Old 09-16-13, 01:00 AM
Lukas99GS
Lukas99GS's Avatar
This is my issue as well I've replaced the pads and the car does stop but I know it should be braking better I have to push a little farther than I think I should to brake, did it fix this for you after the fluid was bled? That's what I'm planning on getting done next
Old 09-16-13, 10:14 PM
PHML
PHML's Avatar
Bleed it and get the old brake fluid and air out....it may feel better at the pedal.
Johnhav430
03-03-19 10:10 AM
Ef8people
03-12-14 12:37 PM
Alant514
01-11-14 12:07 PM
Holland300
Suspension and Brakes
07-09-12 11:42 AM
rtk7
11-14-07 04:52 PM
Quick Reply: How to properly replace calipers?
