LS400 caliper rebuild halves require sealant?
Old 07-13-13, 11:21 AM
kamlung
kamlung's Avatar
Default LS400 caliper rebuild halves require sealant?
i went through all the threads but didn't see an answer on this.
I will be halving the caliper to clean/paint/rebuild it... once i'm done and ready to rejoin the two halves of the caliper together, is there any required sealant/silicone on the mating surface??? or do i just bolt them together and job done???
Old 07-15-13, 09:20 AM
kamlung
kamlung's Avatar
bueller???
Old 07-15-13, 02:26 PM
clos430
clos430's Avatar
I doubt you need sealer but not 100% sure. Do you remember cleaning any off when you removed them the first time ?
Old 07-15-13, 04:48 PM
christodav
christodav's Avatar
Clean and back together
Old 07-29-13, 09:13 AM
kamlung
kamlung's Avatar
for anyone doing this. there is a rubber gasket that goes in between the two halves of the calipers which feed brake fluid to both halves...
NaturalJZ (07-28-20)
Armitage
Suspension and Brakes
04-23-17 04:30 PM
Returd
04-12-17 08:36 AM
vietnamese
16
11-27-05 05:14 PM
RA40
01-02-05 12:52 AM
Quick Reply: LS400 caliper rebuild halves require sealant?
