Bad Strut Bearing?
Old 07-05-13, 06:16 PM
Alphaman19
Alphaman19's Avatar
Default Bad Strut Bearing?
My 98 GS400 makes sort of a short croaning/creaking sound if I stop quickly or backup into my inclinded drive way. I had the upper and lower control arms done about 4 years ago.
I read that sometime the "bearings" in the top of the strut go bad sometimes. Is there a way to tell?
225k miles/Imperial Jade
Old 07-05-13, 07:57 PM
porn-adkt
porn-adkt's Avatar
I would check the Muffler Bearing first. It could be making noise.
Old 07-16-13, 03:20 PM
SHOLEXMAN
SHOLEXMAN's Avatar
^^^lol my guess... NOT! I had this issue as well and my vehicle has 210k on it. The strut top bearings wear out and do make a pop type noise ,but that is usually with going over bumps in the road. The reverse noise 1 time brake engagement pop was from my brake pad shims and the small metal brakets that sit inside the brake bracket. Those move cause the brake pads to pop in a sense. It would also be good to lubricate the sway bar bushing with some grease cause those rub after some time. Lexus sells the updated shim kit and should fix the issue.
prech
10-18-15 06:38 PM
Avster
RX - 1st Gen (1999-2003)
05-23-13 03:05 AM
wed3k
05-29-11 05:12 AM
chenxingha
04-18-11 12:54 AM
ebnub
16
10-06-10 03:20 PM
Quick Reply: Bad Strut Bearing?
