ananybody running megan front camber arms?
Old 01-12-14, 09:35 AM
  #46
antinnous
antinnous's Avatar
Originally Posted by TimWalker
Well I have the uca set in the most positive adjustment possible so it has lots of space but I'm guessing if I were to set it fully negative it would be pretty close but I would have to Jack up the car the measure it exactly.
Anyway the way it is now there are no clearance issues at all.
Hopefully I answered your question but if I can help more let me know.
Thanks for the reply! I was mainly curious because of the pics, it looks like you can only slide your fingers through the gap at the most positive setting. But you say if you can go full negative and still clear is what I wanted to hear. On top of that it looks like your on stock if not only lowering springs, and typically coilovers are slightly thinner profile, thus even more clearance for those who run coilovers with these Megan FUCA's.
Thanks again
Old 01-16-14, 10:07 AM
  #47
RikTT
RikTT's Avatar
TimW, what was your neg camber &/or other specs prior to install and re align specs after ? Curious. And with JUST the Megans installed, full positive as you did, was there any adjustments the alignment showed to toe & caster off the bat ? Thanx
MDHLexus
09-18-15 05:33 PM
DosyBoy
Suspension and Brakes
03-26-14 02:30 PM
seivonecsu
07-10-13 08:51 PM
IS350rock
22
08-10-12 10:50 PM
andrewshu3
119
12-05-11 10:08 AM
Quick Reply: ananybody running megan front camber arms?
