BC Coilover Preload Setting
I have BC coilovers with spring rates 12/10 installed on my IS350 and I was wondering what preload should I use given my spring rates? also not sure if important but i have 18x10 (offset 25) and 18x8.5 (offset 25) wheels with 245/40/18 in the rear and 225/40/18 in the front.
Does anyone know if the coilovers already come preloaded? I got the BCRs but decided to go with the Swift spring upgrade, which meant I had to wait a few weeks before they could ship them out. I have them now and the springs are sitting in there pretty snug. Do I need to re-do the preload or do you guys think I'll be okay?
When I got my BC coils, the mechanic installed them straight out from the box. He was just ignorance or didn't know or care shXX about the preload. Later on, I had to adjust the ride height by myself, so I decided to check the preload of each coil. I found the spring preload-from the factory, of course, is different from one corner to another. So I decided to get the preload right for every corner. Caused me some time to get it right. It is not as easy to do the preload setting with coils installed onboard. If you have time, better check and set the preload "before" install your coils. It will be easier as you can see in the above video.
I checked out videos for the preload which I have never done with my previous coils on my vw's what is the main purpose of doing the preload and once I install them is there a particular way to adjust them to go lower and keep the preload at the same time?
