Pedal to the Floor (BRAKES)
Old 05-29-13, 05:05 PM
SlickRSM
SlickRSM's Avatar
Question Pedal to the Floor (BRAKES)
Having an issue with my brakes.... I have to push the pedal pretty far down to have my car stop completely. I've noticed it for the last month or so, my brakes and rotors are still good just passed inspection. I recently moved to Philly and have yet to take my car in for service at the Lexus Stealership and I don't know shops to check it out. I also don't have any tools at my apt. here. My IS 250 is a 2007 and I have 88,000 miles its still under my extended warranty. I think the Lexus dealership will charge me an arm and leg to look into the issue...
I checked my brake fluid still full
Brakes and Rotors are still good
Checked front brake lines so visible leaks
Anyone have any ideas?
Old 05-29-13, 05:27 PM
Toxicxk23
Toxicxk23's Avatar
There could possibly be air in your brakes lines
Old 05-29-13, 06:34 PM
SCWB
SCWB's Avatar
This is dangerous. I would go the the dealer to have it fixed asap over anything else.
Could be air in the brake fluid system, Master Cylinder goes out/leak, or seized caliper pins.
Old 05-30-13, 07:09 AM
iRyan
iRyan's Avatar
sounds like master cylinder going bad sir...if u have warranty let the dealer look at it
Old 05-30-13, 10:47 AM
UniSlayEX
UniSlayEX's Avatar
I agree with everyone else. If you've done all you've listed right, then it definately could be a Master Cylinder issue. When did you last change your brake fluid? You're coming up on the next change BTW.
Old 05-30-13, 06:38 PM
Gville350
Gville350's Avatar
Could be rear seized calipers.
Old 05-31-13, 10:56 PM
panda08
panda08's Avatar
funny how people call it stealerships, yet go to them for service anyways. dealership techs and advisors only "recommend" you do the services, they don't force you to
Old 06-01-13, 09:53 AM
Dawa
Dawa's Avatar
well **** if lexus is gonna fix it for free, take it to em!
what color is your fluid?
if its dark, i would replace it, hell i would replace it anyways.
and then bleed the system.
and if that doesnt help then you might need to the BMC
rebuilt (replace internal parts.) rebuilding is cheaper
than replacing but it accomplishes the same thing.
Old 06-01-13, 11:40 AM
vicsis250
vicsis250's Avatar
It sounds like its your master Cylinder, get it in to a shop ASAP before you lose braking power
Old 06-01-13, 09:23 PM
SlickRSM
SlickRSM's Avatar
Yea I called the dealership a few minutes after posting i go in Monday morning
Old 06-02-13, 02:32 PM
Denver
Denver's Avatar
Sounds like air in the system or the seals in the master cylinder has gone bad.
Old 06-03-13, 10:49 AM
EXL124
EXL124's Avatar
You should check your rear calipers. Most likely its seized. Same exact thing happened to me. I could not get them unseized...rusted solid. Ended up replacing the calipers, rotors and pads and now the pedal is much tighter and does not have to travel so far to engage.
BTW, you don't have to replace the pads and rotors...mine were just due for a change anyways.
Old 06-25-13, 07:22 AM
SlickRSM
SlickRSM's Avatar
Sorry it took so long to update, well it happened to be both rearcalipers were seized. $800 it cost me and my hands were tied because I just moved and have none of my tools here. Funny thing is this was 3 weeks ago and my pedal again is once again to the floor.
Old 06-25-13, 11:33 AM
UniSlayEX
UniSlayEX's Avatar
You think they've seized again?
Old 06-25-13, 02:51 PM
SlickRSM
SlickRSM's Avatar
I dunno it feels like it, I'm taking it in tonight. When they replaced the rear calipers they told me they would replace the slider pins and well. When I got the car back I noticed they didn't replace the pins because they still have red paint on them from when I painted them. I called to complain about it but I was told they rebuilt them. Its a pin wtf, I spent $800 already I would have gladly paid a little more to get the job done right.
Quick Reply: Pedal to the Floor (BRAKES)
