IS350 caliper upgrade! Need help!
Old 05-22-13, 11:26 PM
DaNiELx626
DaNiELx626's Avatar
Default IS350 caliper upgrade! Need help!
Does anyone know how to remove the brake dust shield cover?! I took out all the bolts and still can't seem to remove the shield...
Old 05-23-13, 01:53 AM
kumquatism
kumquatism's Avatar
You have to remove the hub to remove the brake dust shields. If you removed that already, then just pry at the shield. It's probably caked on, and needs a little elbow grease to get loose
Old 05-23-13, 03:19 AM
DaNiELx626
DaNiELx626's Avatar
ooo i see... how do u remove the hub? lol
Old 05-23-13, 05:17 AM
B16da9
B16da9's Avatar
It's much easier to just cut a small portion of the dust shield and then bend it a bit instead of removing the hub. Unless you already spent the money on the 350 shield
BTW: I've done my previous IS250 and a couple of friends and thats the way I've done it every time.
Old 05-23-13, 06:56 AM
sgmbab
sgmbab's Avatar
I ran into this problem when I was doing mine. It is impossible to remove the wheel bearing to install the dust shield without damaging it. I tried wd-40, prying it off, and yanking it out with the wheel back on. I eventually gave up and just trimmed the dust shields with a snip.
Old 05-23-13, 06:58 AM
whitebeast
whitebeast's Avatar
The hub is holding by 4 bolts on the back, you need to disconnect the speed sensor as well.
Old 05-24-13, 03:57 AM
iRyan
iRyan's Avatar
I'm one of those friends lol
Old 05-24-13, 05:13 AM
DaNiELx626
DaNiELx626's Avatar
so in order for me to remove the hub... i needa bring it to a shop huh? :/
Old 05-24-13, 06:34 AM
B16da9
B16da9's Avatar
Don't need to take it to a shop, you'll just need the proper tools.
Gtpspeed02
08-05-17 12:29 PM
brybo86
05-05-16 08:31 PM
ArkLaTexSC
Suspension and Brakes
03-08-14 10:36 AM
sgmbab
19
04-12-13 05:25 PM
blkonblk17
25
07-19-07 04:06 AM
Quick Reply: IS350 caliper upgrade! Need help!
