Sway bar kit
Old 07-18-13, 08:28 AM
  #46
pdxgs
pdxgs's Avatar
Originally Posted by tmf2004
when installing the front unbolt the brackets first then the endlinks?
Order doesn't matter front or rear. Just don't drop the front bar on yourself, it's fairly heavy.
Old 09-22-13, 09:34 AM
  #47
Sampak
Sampak's Avatar
I clicked on the link in the first post but it was an old listing so I kept clicking the chain down to the newest listing. Unfortunately it's ended and I am unable to find any other aftermarket front/rear sway bar kits on ebay.
Old 09-22-13, 10:55 AM
  #48
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I haven't seen any on eBay in long time. TRD sways are in stock at Sewell but there $$$$
Sent from my iPhone using IB AutoGroup
Old 09-22-13, 10:59 AM
  #49
NorthStyle
NorthStyle's Avatar
Yeah, I'm pretty sure they've been sold out of those for a while now. You may be able to check with the manufacturer though.
Old 09-23-13, 10:01 AM
  #50
Sampak
Sampak's Avatar
Well I guess I'll have to settle for a stock swaybar for now then. Was hoping to experience the whole 'cornering improvement' thing with a bit stiffer bar but any good used one will do for now, I suppose.
Old 09-23-13, 10:19 AM
  #51
tmf2004
tmf2004's Avatar
there's on for sale in the classifieds but he won't ship. you can PM him.
Old 10-19-13, 02:00 PM
  #52
RamAirRckt
RamAirRckt's Avatar
I finally got my front bar on. It is VERY easy, probably 15 min work start to finish. I think I spent more time on taking off the belly pan than the actual bar install/removal.
I reused the stock bushings/brackets, the bushings are for a slightly smaller bar, but they "cram" in there ok. Will see how long they last like that. The factory bushings are good quality and after 201k miles are still in excellent shape.
Adding now the front (I did the rear a while back) the car is nicely firmer than it was with the stock bar. Not as dramatic as the rear only (very good improvement over the stock rear), I love the balance of the aftermarket rear bar and stock front bar. But it needs more front bar too. I'll give some better drive testing in the next week.
Old 10-19-13, 02:19 PM
  #53
NorthStyle
NorthStyle's Avatar
I've been running with only the front for a while now as each one of the rear bracket bolts broke while removing them... tried drilling them out and retapping and didn't workout so well; no clue what to do now
Old 10-19-13, 02:51 PM
  #54
RamAirRckt
RamAirRckt's Avatar
Post pictures, I broke 3 of the 4 bolts and had the drill them out (cobalt bits) and then put in a bolt with a nut. Was a pain, but it worked fine. I drove it for a week or so with no rear bar till I got it done. Drives fine, just not as good in corners.
Old 10-19-13, 04:08 PM
  #55
tmf2004
tmf2004's Avatar
So u have the stock bar in front or aftermarket bar with stock bushings?
you can always buy the energy suspension bushings as replacements
Old 10-19-13, 06:05 PM
  #56
2jS160
2jS160's Avatar
They're back and priced higher @ $149.99 a set
http://www.ebay.com/itm/Lexus-F-R-Sway-Bars-1998-2005-GS300-2001-2004-GS430-1998-2000-GS400-NEW-EMUSA-/281174518921?pt=Motors_Car_Truck_Parts_Accessories&hash=item41774eac89&vxp=mtr
Old 10-19-13, 07:12 PM
  #57
RamAirRckt
RamAirRckt's Avatar
I bought this set a while back and put only the rear on first, for several months (read my posts on this thread), but finally today got around to putting on the front bar. I lost the new bushings and bracket, but I didn't like them anyway. So I reused the stock bushings. It is a bit tight, but factory bushings, not cheap rubber. A reasonably high durometer rubber, and now squished pretty good.
Would love larger bars, as Herb Adams once said, he hasn't a bar too big...
Are you talking solid or hollow bars? For the weight I think I would rather stay hollow.
I would like to see around a 37-38mm front and least a 33-35 rear. Around a 5-6mm wall thickness. I would have to put some thought into it, but if we can make it an adjustable lever, that is a BIG plus. The adjustibility is really the key to make a great handling car even better. The rear is easy, very simple bar. Front is little harder, but still not bad at all.
I have some rare killer Rancho Challenger GTIII bars on my 80 Turbo T/A, 1.25" front, 1" rear, solid, and adjustable lever. How strong? One of the worlds strongest, 900 lb/in deflection in front. The vaunted Herb Adams or HO Racing bars at 1 3/8" were only 550 lb/in. And they are the biggest out there for the B/D/G/F body cars. But the bars are not made anymore and never made in large volumes. Most cars who claim to not lean have no idea what it means to not lean.... The bars power stripped the bolts right out of my frame. But the cornering power was fantastic.
Old 10-19-13, 08:09 PM
  #58
tmf2004
tmf2004's Avatar
it would be great sik of you became a vendor here. these would sell of there priced right.
Old 10-20-13, 01:11 AM
  #59
NorthStyle
NorthStyle's Avatar
I'm running the aftermarket one with the bushings they provided; I'll probably do the same with the rear although I've noticed that the bushings EMUSA provided are shaped slightly different from the stock ones.
Old 10-20-13, 01:51 AM
  #60
tmf2004
tmf2004's Avatar
how is the fitment and are the bushings Poly?
Quick Reply: Sway bar kit
