Sway bar kit
Old 02-21-16, 07:12 AM
  #211
RamAirRckt
RamAirRckt's Avatar
Stock endings yes. Don't know on Daizen bushings.
Originally Posted by GrVitesse
Front Sway Bar Stabilizer Anti Roll Arm Fit Lexus 98 00 GS400 98 05 GS300 | eBay
Will these work with the stock endlinks + Daizen bushings?
Old 02-22-16, 03:34 AM
  #212
GrVitesse
GrVitesse's Avatar
Thanks - very good to know.
Do you know which poly bushings would work with these?
Old 02-22-16, 05:16 PM
  #213
firelizard
firelizard's Avatar
30 and 20mm
Old 02-22-16, 10:55 PM
  #214
FIGS
The Maker
FIGS's Avatar
We have 3 bar sets in stock with lifetime bushings and solid construction.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 02-23-16, 01:15 AM
  #215
GrVitesse
GrVitesse's Avatar
Originally Posted by firelizard
30 and 20mm
Does anyone know which brand makes polys in these sizes? It seems the Daizens are sized for the (smaller) stock bars and the Prothanes are 28.5mm front and 14mm rear.
Are sway bar bushings model-specific, or can there be some interchangeability?
Old 02-23-16, 06:14 AM
  #216
firelizard
firelizard's Avatar
Prothane makes universal sway bar bushings in a variety of sizes
Old 02-27-16, 01:41 PM
  #217
GrVitesse
GrVitesse's Avatar
Thanks- ordered these from Amazon:
https://www.amazon.com/gp/aw/d/B0038...?ie=UTF8&psc=1
I'll report back after installation.
For future reference, I just received an email from TM Engineering confirming that the Daizen sway bar hasn't been in production for years. It's still on their website as if one can order it, though.
Old 02-27-16, 02:01 PM
  #218
RamAirRckt
RamAirRckt's Avatar
Anyone know where to get 19 or 20mm rear bushings? One of mine is shot (aka, missing...)
Old 03-15-16, 08:10 AM
  #219
02LexGS
02LexGS's Avatar
For those of you who have bigger sways, what style bracket did yall use? Type a or type b?
Old 03-15-16, 10:39 PM
  #220
GrVitesse
GrVitesse's Avatar
So I installed the Ebay "EMUSA" front and rear sways with Prothane bushings (linked above) and stock links. My GS400 handles like a different car now - on hard, tight turns it'll stay upright and lose traction before the body has a chance to lean. Faster, safer, smoother, and still rides as gently as before when driving in a straight line, but much more stable feeling at high speeds. This is amazing, and I'm surprised that Lexus didn't make them like this in the first place. Thanks for the help and recommendations.
Old 03-15-16, 10:56 PM
  #221
02LexGS
02LexGS's Avatar
Did the brackets and bushings you order fit perfectly?
Old 03-21-16, 12:21 PM
  #222
GrVitesse
GrVitesse's Avatar
They did. The hole in the rear bushings was a little too wide, but it closed up when the bracket was tightened.
Old 03-27-16, 05:55 PM
  #223
02LexGS
02LexGS's Avatar
Just installed these and I agree, the car is a completely different car now. 3 days after installing these I switched to some Michelin Primacy mx4 and installed Bilstein Sports with Eibach Pros. Feel like im driving my old bmw instead of my lex. Definitely recommend
Old 04-03-16, 05:14 PM
  #224
Justmeez
Justmeez's Avatar
To you guys who recently installed both the front and rear, did you have any issues getting the rear bar in?
This is my first go at suspension but I can't for the life of me figure out how to get the rear bar installed with links. I have new ROCA links btw. From my observations this bar is slightly longer than the stock and the ends have a slant: / \ or \ / depending on how they are flipped. Any suggestions would be great.
*I have the ebay kit btw*
Old 04-03-16, 05:35 PM
  #225
badblackgs
badblackgs's Avatar
after reading all thru this thread, i did some searching and found the same ebay emusa sway bars 31mm front and 20 mm rear. I pulled the trigger and super excited to get them on. I also contacted figs engineering and chris the salesman hooked me up with some blue poly. sway bar bushings that fit the sway bars i ordered perfectly. they come in 31mm front bushings and 20mm rear bushings with the recommended grease. they cost me 67 shipped and they have a lifetime warranty. as soon as i get the bars on ill report back my review. #can'twait
Quick Reply: Sway bar kit
