will a sway bar make a difference
From experience I would get both. My opinion is you get the rear notice a difference, you wonder what could the front do and are back at square one again. The rear is def. noticeable the front is iffy but because we don't notice a difference doesn't mean the part isn't doing what it is supposed to. Personally look around and see is250, 350, F. If you like to control your car the set is where it is at.
F-sport front and rear sways are well worth the money. Go to Sewell. You'll be very happy with the results. I did the combo on my is350 and it completely changed the characteristic of the car. Best bang for the buck as far as handling.
it stiffens up the steering, more of a feel thing than anything. Swaybar set will improve actual handling, not just feel. May want to consider the steering damper if you dont like the increased vibrations and stiffness you feel when you have a modified suspension. $26 mod, took 10 minutes to install. I had noticeably increased vibration since the sway bars made the suspension more rigid. When I put the damper in, it returned it to what it felt like stock.
I'm thinking to get the sway bar set. From what everyone is saying, I'd get both front and rear.
Besides better cornering, do you get a rougher ride with sway bars?
And, is there a difference is the sway bars are on a 2012? Not sure if there was a difference in the suspension between 06-10 vs. 11-13 models.
Thanks.
Thanks.
Good luck!! You'll love the results!!
