BC coilover owners chime in
i have the extreme kit also, however cant go crazy low cause i wouldnt make it out of the driveway.lol. but i have a 1 finger gap on 19x9 and 19x10. its comfortable but still looks good. had meagans but prefer the bc. im using 12/10. for special events or shows jus drop it to what looks good. then raise it back up jus remember you settings.but once you get them post some pics.
I have the Xtreme drop kit, 10k front 10k rear spring, 19x9.5 and 19x10.5, 35 series side walls, and I am pretty low.
Car is driven 75+ miles a day without any issue. FL roads are pretty good though.
Thats odd mine rides like a dream on full stiff. They must have revamped things for the SuperSport series. Unless you did what many others have done and lowered the car by unlocking the spindles and dropping the spring. By doing that you dramatically shorten the travel of the strut giving you a harsh bumpy ride. With Stance they are designed to be lowered by spinning the lower cup downward. This allows you to do at least a 4 inch drop without affecting the strut travel. Since the coilover is far shorter then stock suspension I was able to achieve a pretty slammed fitment on 19's by only dropping an inch on the lower cup. I could go way lower with Stance and still keep the maximum strut travel.
ok i finally figured out which spring rate i want but im gonna be riding on 20s for now. will i rub with the extreme drop kit at its highest? idk whats the highest compared to stock will the extreme be. eventually i will be going 18s or 19s but i wanna make sure im good for now.
