06 250
06 250
Good Morning Everyone,
I tried a search for this and I couldnt find anything, I am sorry if I missed it. I need to do my brakes and was going to replace my rotors. I wanted to know what does everyone recommend for cross drilled rotors. I dont need anything crazy just something that works well.
Thak you in advanced,
Javi
Javi
Try sportstop xdrilled brake rotors, i've heard they're pretty good and its centric.
http://www.rockauto.com/catalog/x,ca...,parttype,1896 -> This is the cheapest place to get them, that I've found
they're functionally inferior to blanks and wear out your pads faster too.
Unless you track the car there's no functional reason to use anything but OEM replacement blank rotors (Centric is a good, less expensive than Lexus, brand to use).
If you DO track the car then slotted rotors, without those useless structure-weakening holes drilled in them, would be the way to go.
If you prefer looks over functionality and service life though, knock yourself out with any name brand drilled rotor.
