Springs + Camber kit?
Hi CL, noobie here
I was curious to which would be better suited for my 2IS needs. I'm currently on H&R springs and picked up a set of wheels. Rear 20x10 +25 offset with 245/35/20 tires. I know for a fact that I will have rubbing issues in the rear. I have an option of either a fender roll/pull or just purchasing a camber kit. Would it be wiser to just get the camber kit now if I'm purchasing a coilover kit in about 4-5 months? Will I still look high/add more wheel gap in the rear with the camber kit
Fire Slayer
The camber kit will allow you to run aggressive and let you tuck the wheel in the wheel well. You can get the kit now and the coils later and dial in the exact height you want it at. You should go with 30 series tires also. I have a camber kit maxed out and am slammed static. The kit doesn't mess with ride height (look high) or add wheel gap. This is how I have my 20x10.5's on 255/30/20. Hope this helps and welcome to CL.
bboysunone
04-14-13 12:38 PM
