IS350 brake conversion!
I know there's a few threads out there that has the front conversion questions and DIY and alot of other helpful information. I just want to be sure that this is all the stuff that is needed for this setup.
So far what I have is...
- IS350 front calipers(would I use my 250 bolts on the 350 calipers?)
What I would need would be
- Front Shim Kit
- IS350 brake dust shields (I was looking around Sewell but couldn't spot it)
- Front fitting Kit
- Front Rotors
- IS350 OEM brake pads
A few questions I have to ask are...
Would I use my 250 bolts/screws on the 350 calipers?
Where is the 350 dust shield located on Sewell? (tried search but couldn't find)
If my calipers didn't come with sliding pins(something like that) how could I order some?
Is there anything else I should need or is that set?
Thank you guys.!
- Front Shim Kit
- Front fitting Kit
- Front Rotors
Thank you guys.!
Thank you guys.!
Thank you guys.!
2) I'm not exactly sure where. You can try emailing/PM-ing them.
3) the caliper pins (one for each caliper) should come with the calipers - if not, hit up Sewell!
4) brake fluid and a hose/container for bleeding the brakes, brake quiet geese to put in between the shims, and a C-clamp to help push the pistons out of the way so u can slide the pads in easier.
... I think that should be it...!
Ling2IS
Suspension and Brakes
01-30-17 02:33 PM
