Homemade rca spacers
Old 08-11-14, 11:51 AM
Mumble88
Mumble88's Avatar
Hey Gs4 are you still riding with these on? If so, how are they holding up? anyone else tried this? Thanks.
Old 08-12-14, 09:04 PM
maxx430
maxx430's Avatar
ahh...i see what you did. nothing goes to waste. very neat.
Old 08-19-14, 08:00 PM
johhntran
johhntran's Avatar
dang awesome never thought of this! way to think outside the box
Old 08-24-14, 04:04 PM
boostedsi
boostedsi's Avatar
looks good
Old 02-10-15, 01:07 PM
SDGSPW
SDGSPW's Avatar
Does your front suspension clunk when turning slowly? I have RCAs as well and they clunk once they release tension due to the torque applied by turning the wheel. I have tightened them down, but I can't get rid of the clunk completely.
Anyone else have this problem?
Old 04-16-15, 08:52 PM
mista714
mista714's Avatar
Nice method! Usually most people use the flat washers if they're cheap like that.
Old 04-18-15, 11:01 AM
Agent0024
Agent0024's Avatar
If you guys have access to a machine shop then use the Solidworks file that I posted a while back. It was for a 30mm but you can modify the height to your liking. I cut a couple pairs for myself and they're still fine after three years.
Old 04-19-15, 10:24 PM
Aristo722
Aristo722's Avatar
Do they clunk when you turn or anything?
Old 04-20-15, 08:17 PM
Agent0024
Agent0024's Avatar
Not at all.
Old 04-22-15, 02:02 PM
TableSyrup
TableSyrup's Avatar
Maybe I'm off here, but doesn't this put more strain on the bolts and the threads they run into?
Not bad mouthing this... very resourceful, and what I think is a good idea.
I would probably weld them to the lower ball joints for good measure, but I like to over do things
Old 08-08-17, 02:02 PM
Noosik
Noosik's Avatar
nice idea, but did these cleared enough space for LS400 brakes, or some grinding of cappilers was still needed?
Old 08-09-17, 07:11 AM
sakataj
sakataj's Avatar
you should NEVER grind a caliper. i have seen it but its one of the stupidest and unsafe things you can do....
Old 08-09-17, 08:00 AM
Noosik
Noosik's Avatar
I`m not gonna grind anything, just want to know if using RCA made of old LBJ will clear enught space for mounting LS400 cappilars..
Meraki Autoworks
IS F (2008-2014)
13
12-07-11 05:11 PM
TOMLEXUS
04-18-08 04:47 PM
_adiO
SC- 1st Gen (1992-2000)
19
03-09-08 09:56 AM
*IS350*
02-28-07 07:01 AM
Quick Reply: Homemade rca spacers
