Do most of you run camber kits? iRyan, my setup will be similar to yours and I was just wondering if you ran camber kits or did you just roll and pull the fenders?
This thread helped alot, I myself will be buying BCR's soon.
It all depends on your wheel and suspension setup.
If you go really low with aggressive offsets, I would use a camber kit so your tires dont get worn out right away. But your offsets are not that aggressive, you shouldnt have too much camber. I only have -1.5F and -2.5R degrees of camber and Im tucking tire. The only fender mod Ive done is relocated the fender tabs, no rolling or pulling
i didn't run any camber kits...my setup is not that aggressive to need it...for the front I relocated tabs and heated up the fender liner n thats it...for the back I shaved the fender lip and thats it..
