Supra tt tokico hts shocks and lowering springshi
Old 01-09-13, 05:47 PM
Kakaroto
Kakaroto's Avatar
Default Supra tt tokico hts shocks and lowering springshi
hi every one and happy new year. I just purchased a set of tokico hts shocks and lowering springs for Toyota supra tt and KYB rear strut mounts for supra tt. But when I intended to insert the shock in the strut mount hole it won't go in. The flat surface won't let it go in. Anybody here have this setup? Any ideas?
Old 01-09-13, 07:06 PM
Candela
Candela's Avatar
Listen goku, IIRC, the top of the shock has a rectangular shape, as does the shock mount
Old 01-09-13, 08:07 PM
Kakaroto
Kakaroto's Avatar
Yes but thats the point. It stays there and dont want to go in. if you push it will damage the thread
Old 01-11-13, 02:33 PM
ttsukamoto
ttsukamoto's Avatar
I recently just installed bilsteins and tein springs and had a similar problem. The threaded portion of the shock was a tight fit and I too was worried about damaging the threaded shaft on my new set of shocks. In my case, I made absolutely sure that the alignment was correct and I very gently (hand pressure only, no tools, mallet etc) wiggled the top hat onto the threaded shaft. It also helps if you test fit the top hat without the spring loaded into the shock. It worked for me and no threads were damaged. Good luck.
Old 01-15-13, 08:28 PM
Kakaroto
Kakaroto's Avatar
Thanks alot guys for the replay. Loco muchas gracias. They send me the wrong part, I just reseaved the correct one today. And the rood got in like butter.
Old 01-25-13, 07:16 AM
greens14
greens14's Avatar
hand file would also work
RyanR317
Suspension and Brakes
09-02-13 06:34 PM
LyFeWoRx
06-01-08 12:25 PM
Tony95sc4
11-13-06 08:18 AM
Sc1UZ-FE
04-28-06 01:47 PM
mrshabo
02-01-04 08:24 PM
Quick Reply: Supra tt tokico hts shocks and lowering springshi
