brake bleeding problem
Old 09-13-12, 12:52 AM
qwerty04
qwerty04's Avatar
Default brake bleeding problem
i replaced my front pads on my 98 gs400 today. i started to bleed my brakes starting with the rear right. had someone step on the brake pedal then i opened the bleeder until i seen a stream of brake fluid with no air. then i closed the valve and he let off the brake pedal. did it again just to make sure no air was in the brake line. then when i went to do the rear left no fluid would come out. tried it a few times and gave up. last week i changed just the rear pads with out bleeding the brakes. the pedal wasnt too bad. now the pedal reaches to the floor. any one know what could be the problem.
Old 09-13-12, 06:41 AM
CleanSC
CleanSC's Avatar
You did make sure to add brake fluid into the master cylinder reservoir, right?
It never went dry at any point?
Old 09-13-12, 09:42 AM
qwerty04
qwerty04's Avatar
nope. never went dry
Old 09-13-12, 10:35 AM
CleanSC
CleanSC's Avatar
Might still have air in the system. Did you follow the proper bleeding procedure as stated in the manual?
Old 09-21-12, 12:16 PM
GS4hunnit
GS4hunnit's Avatar
Was the key on the "ON" position. I believe the rears are electronically controlled. And, i also think you should start with the fronts first.
bauer26
GX - 1st Gen (2004-2009)
03-09-13 10:48 AM
Lexus082
Suspension and Brakes
10-13-12 05:40 PM
Lexus082
06-21-11 05:39 PM
Avarec
SC- 1st Gen (1992-2000)
04-14-10 02:27 AM
GMoney
03-24-10 06:42 AM
Quick Reply: brake bleeding problem
