Common Problem - ABS Light after 1jz/r154 swap. How 2 Fix??
Info on my car:
JZA70 1JZ
Soarer Harness
Soarer auto ECU (neutral bypass)
r154 with oem extended shifter
I finished my 1jz swap last month, and now I have the ABS Light on. I've searched and searched and cannot find a fix for it, all I can find are post about the ABS Speed Sensor....
- But I thought the ABS speed sensor is for a R154 in an MK3 Supra because the JZA70's didn't have ABS?
- If it is the abs speed sensor, how/where do I install it? I had a member on SF.com tell me this below, but he was referring to a '92 Jza70 supra. Would wiring be the same in the SC300? If not, where can I find the wiring diagram for ABS in a SC300?
- And the only other thing I can come up with is that my soarer harness has traction control, but my car itself doesn't....could that be the issue?
Any info or help would be appreciated
JZA70 1JZ
Soarer Harness
I used a spare 4-wire connector wired to the sensor and at the dash connector... You have to create your own connector/run with what you have available.
You have to run each wire from the speed sensor, to its corresponding spot, in the B3 connector.
I have a 1995 5spd (no traction control) chassis
with an automatic (no traction control) 1992 1jzgte Soarer engine set.
The ABS light is not on.
92 SC300 5-speed non-trac.
Soarer 5-speed non-trac swap (year unknown).
No light and I'm almost certain my ABS works
supradean
Performance & Maintenance
02-27-07 02:33 PM
